02-25-2012, 11:40 AM
elevator trim server
hi there,
has anyone expereinced a runaway elevator trim server installed on a RV-8 / 8A or any other RV model ? Is there any way to limit the maximum trim stroke on the server ?
cheers,
Josef
02-26-2012, 12:37 AM
Originally Posted by Josef
hi there,
cheers,
Josef
You could make the control horn on the trim tab taller, this would reduce the travel of the tab for a given servo travel.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
02-26-2012, 12:53 AM
thanks Colin, will consider this solution.
02-26-2012, 02:21 AM
The critical factor is to ensure the servo itself reaches its own limit stop prior to any linkage binding.
If a trim runaway does occur, binding will load the linkage parts and these might fail while sufficient force is being applied to the control stick to overpower the trim. A failure of the linkage under these conditions could easily result in a greater than max g pitch input.
Doug Gray
RV-6 completed, flying since July 2010
02-26-2012, 05:41 AM
hi there,
cheers,
Josef
If you're referring to Ray Allen Co. servos, they sell a "travel reducer" that is a small plastic part that can be inserted inside the servo to limit stroke. I had to use one once for a rudder trim tab that I designed. The instructions that come with it says that it reduces travel by .2 inch. Not very expensive at all as I recall.
02-26-2012, 07:55 AM
On my RV-8 I find that I need all (or most) of the available servo travel to be able to trim across the full range of airspeeds. The servo reaches its internal limits before there is any binding of the linkage to the trim tab; it therefore doesn't appear necessary to limit travel for that reason. Preventing or limiting runaway trim is a different question though.
Alan Carroll
RV-8 N12AC
02-26-2012, 09:25 AM
hi Allan,
which type / model of server are you using for the elevator trim ?
rgds,
Josef
02-26-2012, 10:33 AM
FYI; during phase 1 I have flown with full nose up and full nose down trim and it is not a big problem.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
02-26-2012, 11:03 AM
hi Allan,
rgds,
Josef
Josef,
It is a MAC servo that I bought in the late 90s. I believe its a MAC 8A, which is equivalent to the Ray Allen T3-12A (I'll need to look at it to be sure).
Alan Carroll
RV-8 N12AC
02-26-2012, 06:07 PM
Jim, I would be curious to know what airspeeds you flew at while over riding full up and down trim??
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
