Old 02-25-2012, 09:12 AM
GEM930 GEM930 is offline
Lightbulb Taper pin for nose gear leg.
I'm replacing my 320 with a 360 and my old engine mount went with the 320. We swapped mounts and now I'm wondering about the best way to install my old gear leg in a new mount. The hole in the leg is 3/8" and was fitted with a close tolerance bolt. The hole in the new mount is considerably smaller. Is 3/8 to large of a hole to ream for the correct taper pin? Is a taper pin really that much better than a correctly installed close tolerance bolt? Any thoughts or suggestions would be appreciated.
Old 02-25-2012, 09:24 AM
Rupester Rupester is offline
Default FYI ...
From what I've read, reaming the gear leg with the required tapered reamer is a nasty process. That gear leg is a very hard alloy; machining it in any way is not child's play. I originally planned on using the tapered pin, but when I saw how difficult the process was, I went with Vans' bolt. FWIW.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-26-2012, 09:37 AM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up Oversize Bolt IN STOCK, Reamer and Oversize Washers.
Not Tapered .016 oversize
1st Oversize Bolt
http://www.gen-aircraft-hardware.com...=NAS6605%2D24X
Reamer
http://www.gen-aircraft-hardware.com...PRTL%2D%2E3265
Oversize Washers.
http://www.gen-aircraft-hardware.com...14226%2D64C516
We sell these regularly.
You can use whatever nut you so choose, I would recommend an all metal locknut
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 02-26-2012, 09:43 AM
paul mosher
Posts: n/a
Default Reaming
Use lots of Boelube.
Old 02-26-2012, 10:12 AM
1st Oversize Bolt
Reamer
Oversize Washers.
The hole in the leg is already drilled for a 3/8 bolt (close tolerance). The mount is new and has smaller holes (5/16 maybe??). An oversized 3/8 bolt or a taper pin seems to be my options. Just wondering if there is any reason a taper pin is considered better...Or if it would even work as the smallest diameter of the taper would have to be better then 3/8". Not sure how much taper they have, but I'm concerned the large diameter of the taper would not leave enough material (particularly in the top hole in the mount). I would much rather ream the over sized 3/8 than the taper, but if people have opted for the pin is there a reason, or is it just over kill?? Since the thing is off I want to do it once and not have to worry about it again.
Old 02-26-2012, 10:19 AM
bkthomps bkthomps is offline
my reamer went right through my gear leg like butter
the key is speed, and lubrication, you drill the hole undersized, then ream to final size, that might help some as well
Old 02-26-2012, 10:38 AM
Did you go with the close tolerance bolt or taper pin?
Old 02-26-2012, 07:09 PM
GAHco's Avatar
Cool I guess I was speed reading earlier, I am with you now..
We may have an oversize 3/8 bolt that will fit.
From what I have heard Van's approves the 3/8, I would think that .016 more would not be a problem, but I am not the authority, but Van's is.
Let me know if you need me to scare something up for your fix.
Get em in the Sky!
Tom Brink Pres.
