There are two types of engine driven fuel pumps available to the 540 depending on the model. There is a dual diaphragm pump and a rotary vane pump. Both are positive misplacement pumps but the rotary ones can be a little iffy for self priming, if they have some wear, without the boost pump to get them wet first.
Good luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
