02-23-2012, 08:23 AM
Crankshaft Flange Protection.
Hi,
Simple question I hope.......... what do the experts recommend to prevent corrosion on the crankshaft flange before fitting the flywheel and prop if anything? I am concerned about the dissimilar metals, alum/steal if any moisture gets between them.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
02-23-2012, 10:13 AM
If your engine is new/fresh, there should be a nice cadmium plating on it. It should be enough protection. It also gives a galvanic buffer between the steel flange and the aluminum flywheel. For sure don't paint the forward face & pilot.
Actual repeat offender.
02-23-2012, 10:47 AM
Same question I have. My clad plating is worn off and I did find a little corrosion on the flange, I cleaned it up using Corrosion-X, there?s no pitting. How can I protect my flange?
02-23-2012, 11:12 AM
Very, very LIGHT, SEE THROUGH coat of zinc chromate primmer.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
02-23-2012, 11:20 AM
Good Luck,
Mahlon
Thank you Sir, will do!
02-23-2012, 11:52 AM
Its an old engine which I had rebuilt a long time ago. I has been pickled and I did the crankshaft AD today and the inside was fine. A little suface rust on the face of the flange easily cleaned off...................so zink chromate it will be.
Thanks Mahlon
Steve Arnold
England
02-24-2012, 02:15 AM
Mahlon PM sent
Hi Mahlon can you check your PMS.
Steve Arnold
England
02-24-2012, 10:17 AM
Zink phosphate?
Good Luck,
Mahlon
My maintenance shop hear on the field says you can?t get Zink Chromate any more but will sell me Zink phosphate. Will this be ok?
02-24-2012, 10:31 AM
I believe this is the real stuff...
http://www.aircraftspruce.com/catalo...mateprimer.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
