Old 02-22-2012, 09:19 PM
SeanB's Avatar
SeanB SeanB is offline
Default SafeAir Pitot Mast
I'm getting ready to close the left wing and will install the SafeAir Pitot Mast. I've noticed many builders use a small piece of angle to integrate the mast to a neighboring rib for more stability.
I had to move this mast one rivet hole to the outboard side to center the flange. This negates the angle reinforcement idea since I'm now too far from the rib.
Any concerns if I just install the mast as-is for stability and possible skin cracking? Anyone else not using angle?
Thanks!
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 02-23-2012, 09:38 AM
bruceh's Avatar
bruceh bruceh is online now
I installed it to the manufacturer's instructions. It is tied in to the spar flange and skin. No angle to any ribs. Seems to be very stable, but I'm not flying yet...
Bruce Hill
2020 VAF donator
Old 02-23-2012, 10:38 AM
randyintejas's Avatar
randyintejas randyintejas is offline
Just did this a couple of weeks ago. Without looking at anything I just proceeded to do the task and I was really concerned with it so, I added angle to the closest rib. My concern (maybe unfounded) was skin cracking from pressure caused by the air force on the tube. After I was done I looked at other builder sites and saw they did the same. I always do everything backwards first.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-23-2012, 02:43 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
I added a brace across two ribs...this picture gives an idea (the yellow paint is brushed-on zinc chromate).
Ralph Finch
RV-9A QB-SA
Davis, CA
