I had the same exact thing happen to me once when removing the breather fitting. Extractors don't work very well because they actually make the situation worse. The best tool to use is to take a piece square HSS steel, like a lathe toolbit, and grind four tapered flats on it and drive it in so that it cuts into the left over threaded part, then wrench it out. My dad, who was a tool and die maker, taught me this one.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
