Old 02-20-2012, 03:40 PM
lockeed's Avatar
lockeed lockeed is offline
Default Ground fuel gauge level vs flying fuel gauge level
What do you guys think is the difference in gal. between "level flight" gauge indication and "ground" fuel gauge level indication.
I think I'm showing 5gal. more when I'm on the ground....
RV-6A
Old 02-20-2012, 03:44 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default On my RV-4...
With 5 gallons in the tank my fuel gauge reads 1/4 tank in the level position, and 1/2 tank in the ground (3-point) position.
Or is it the other way around? I have it marked on my panel...
I don't know if this helps you with your plane...
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 02-20-2012, 03:51 PM
My fuel indicators from Vans are very precise below 10 gallons. Level the same either on the ground or in the air. If needle gets to zero I have exactly three minutes @2200 rpm rich until it coughs Tested during Phase One.
Old 02-20-2012, 04:21 PM
flyinga flyinga is offline
On the Dynon the gages read about 3 gal more in the three point attitude than level flight (which I hardly ever see!). With the nose down the gages read lower than level.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 02-20-2012, 04:25 PM
lockeed's Avatar
I should also say that i have the Vans gauges.
Old 02-20-2012, 06:10 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
I have a skyview, I found that the fuel computer is very close ( with in 2 lts ) of whats inside the tank. This is with the vans float type sender, and red cube fuel flow.
I still have trouble getting my head around, that when I look inside the fuel tank and only just see a bit of fuel, that I still have 20 ltrs inside, good for another 3/4 hour.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
