Dinitrol AV-8
I used Dinitrol AV-8 (since bought by Ardrox and renamed Ardrox Av-8) on my Cessna 150 and I think it has done a good job. It is however, messy to apply and remaines a bit sticky in service, so if you are crawling around in your tailcone or poking around inside the wings, you can get some on yourself. Also weeps from lap joints, as it should to protect the joint, but if you subsequently paint the exterior, you must be very careful to remove it.
Cessna recently released service letter SEL 51-01 recommending the use of corrosion inhibiting compounds. They recommend CorBan 23, which they manufacture, as well as CorBan 35, Ardrox AV-8, and Ardrox AV-15. Of course on the affected airplanes, Cessna did not primer the interior parts.
I think priming parts prior to assembly provides better anti corrosion protection, although it is more time consuming. I am using epoxy primer over Alumipreped and Alodined aluminum on my RV.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
