Old 02-20-2012, 02:43 PM
tc1234c's Avatar
tc1234c tc1234c is offline
I missed the last paragraph of Bruce's post. I agree with Mel that VS and rudder of 7 and 9 are the same. HS and elevator hinge openings are the source of the whistle. I had them covered for a few years until my duct tape fell off. Now I am whistling in the sky again (as Wayne G. has observed).
Ted Chang, VAF #681
2018 Due paid
Old 02-20-2012, 02:45 PM
airguy's Avatar
airguy airguy is offline
How do you cover the holes such that you still have full elevator travel? I assume you're not covering the elevator-HS gap - just the elevator cutouts? Got any pictures?
Old 02-20-2012, 04:39 PM
DennisRhodes DennisRhodes is offline
Question Horz stab end ribs.
I notice one post indicated that the horiz stabilizer end ribs which have an obvious lightening hole exposed to the elements at times may also be part of the cause. Anyone tried taping just that hole to see if the whistle stopped? That appears quite easy job. Not sure I understand how to tape off the rudder or elevator rod end attachment holes, besides all the other models have same type opening as the 9 on those.
Old 02-20-2012, 05:44 PM
jjconstant's Avatar
jjconstant jjconstant is offline
Default the answer is obvious...
...they whistle 'cause they're just happy
Jeremy Constant
Old 02-20-2012, 05:53 PM
N941WR's Avatar
N941WR N941WR is offline
If I had to guess, and this is only a guess, I would suspect the flap hangers.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-20-2012, 06:02 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
With just the rudder hinges taped I haven't heard anyone comment about whistling from my plane, but then I never asked anyone to listen for it. Next time I am at the airport I will have someone do just that.
The elevator hinges make sense because the -9 horizontal is bigger and it may make an effective resonator more so than the other, less awesome, RVs.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 02-20-2012, 06:10 PM
rv9aviator rv9aviator is offline
This may be a silly question but could the whistle also be a source of drag that might effect airspeed. I hope not because I kinda think it's cool.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 02-20-2012, 07:01 PM
tc1234c's Avatar
When I had the tape on I only taped the bottom openings (used yellow duct tape to match my paint) to the extend that does not interfere with the down elevator. Yes, it is very easy to test.
Ted Chang, VAF #681
2018 Due paid
Old 02-21-2012, 05:53 AM
dedgemon's Avatar
dedgemon dedgemon is offline
If its making noise, its making drag!
Never noticed any whistling on my 9. Can't say I've really noticed it on others either. Probably just a little plane to plane variation.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 02-21-2012, 06:50 AM
smithhb's Avatar
smithhb smithhb is offline
Mine doesn't whistle...
Bret Smith
RV-9A Flying (N16BL)
Blue Ridge, GA
EAA Technical Counselor #5429
APRS Tracking
http://www.FlightInnovations.com
