Old 02-19-2012, 04:30 PM
boom3's Avatar
boom3 boom3 is offline
Default Poor baffling or lean cylinders?
Fixed Pitch / IO-360B1B / Vertical / 2 Mags
Cylinder #2 and #4 are the hotter of the bunch.
On a relatively short 2nd flight today, I'd tried to make a good graph of my question.
Already warmed up from my previous flight, I climbed to about 3000, leveled off, and reduced power. Shortly there after I began leaning to peak EGT, then flew for a bit approx 50 degrees LOP. Then I enrichened to 75 ROP and flew around a bit.
You can see the the large CHT spread, approx 25 deg, during takeoff and ROP operations. LOP yields a significantly smaller, approx 10 deg, spread. If my baffling was poor on #2 and #4 wouldn't the spread stay the same?
By the way I don't think my baffling is poor, but I guess it could be.
My EGTs peak about the same time.
Already checked timing, senders, etc.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 02-19-2012, 05:55 PM
mike newall's Avatar
mike newall mike newall is offline
Our #2 & #4 are hotter by a similar margin.
TMX-IO360 dual P-Mags, low curve, plenum, well sealed elsewhere.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 02-19-2012, 07:28 PM
AlexPeterson's Avatar
25 or 30 degrees between cht's is quite good. It is very tough to get all the conditions the same for each cylinder - mixture, cooling air, etc.. If engine is new or rebuilt, don't worry. Just when you think you have it dialed in, it will change...
It is not simple to even determine if the readings are all accurate in flight.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
