Old 02-18-2012, 01:46 PM
Gregg Brightwell's Avatar
Gregg Brightwell Gregg Brightwell is offline
Exclamation Opinions on some surface corrosion...
Ok guys, I am trying to remember back from A&P School about corrosion....I cannot recall which type of corrosion this is... (pic below).
Again, I bought my wing kit 2nd hand in April 2010. Little had been done, so inspection of all parts was easy. I knew that it only came with 3 skins. (2 bottom outboard, and one top outboard.) All 3 skins were stored leaning against a wall in a metal shop on a concrete floor. Bottom line, all 3 outboard skins have some of the white powdery corrosion shown above. I HAVE looked at my AC43-13, and can't find what I am looking for there. I HAVE also done a search for corrosion here, and found one issue similar. I have taken a scotchbrite wheel in a dotco, and can fairly easily clean it off. Under the whitish powder, it is pitted a bit. (Again though, I can clean it ALL off with the dotco) I think I can clean it up, alodine it, and then prime. If this is a bad idea, tell me, just be nice about it. Lastly, out of curiousity, how much 'coverage' of this corrosion would be grounds for rejection of a skin?
Gregg J. Brightwell
Benton, KS
CFII/MEII, ATP, AGI, A&P
-4 Emp and Wings complete!
Fuselage out of the jig!
www.mykitlog.com/gbrightwell
Old 02-18-2012, 02:26 PM
chaskuss chaskuss is offline
Default 90%
Gregg,
General rule is that you should remove all pitting and blend [bevel] the area where you had to remove the metal. If you have to remove more than 10% of the material thickness [ie .0025" on a .025" skin] the part should be scrapped, due to weakening of the material. Be sure to prime any area where you break through the Alclad layer [about .0005" thick]
Charlie
PS The 90% rule is not absolute. If you have to go further, contact Vans to see if it will be a problem. Their decision will depend on the area and the part.
Old 02-18-2012, 03:58 PM
Sparky's Avatar
Sparky Sparky is offline
I'm no expert, but since you asked, I believe that type of corrosion is called filiform corrosion. I could be wrong.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 02-18-2012, 04:20 PM
Rick_A's Avatar
Rick_A Rick_A is offline
I believe this is uniform surface corrosion that is progressing towards pitting
I would agree that it does look something like filiform, but filiform is normally found under a paint when the metal was not properly treated prior to painting.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
