Old 02-14-2012, 02:46 PM
lockeed's Avatar
lockeed lockeed is offline
Default Help with carb fuel inlet screen removal/re-install
I'll be at the hangar tomorow and I wanted to clean the screen from the carb fuel inlet. Never did it on a Marvel Schebler.
I basicaly wanted to know if you guys put some teflon or green lock tite on the threads when you re-tight the hose?
If you have any tips or things that I should look for, now's the time to let me know!
thx
Old 02-14-2012, 02:52 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Definitly not Teflon
Do NOT use teflon or any thing that will clog the fuel jets in the carburetor!
Follow the recommended Manufacturer guidelines or have someone who has experience talk you through it the first time. As I recall you will need a new fuel strainer gasket but I could be mistaken. Rocket bob (An RV builder and A&P) would be an excellent source as well as Walt Arnow another A&P/RV builder. Just my .02
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 02-14-2012, 03:32 PM
Walt's Avatar
Walt Walt is offline
Just be sure to clean the surfaces and the gasket, no thread sealant required, the copper gasket does the sealing.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
