  #31
Old 02-29-2012, 06:23 AM
cyberpilot10's Avatar
cyberpilot10 cyberpilot10 is offline
Default Cousin Vlad
Hey Tony
would you talk your cousin Vlad into putting some paint on his naked 9A.
If he is not careful, he is going to busted for " I.I.E." International Indecent Exposure of bare aluminum. Ha Ha Ha! There has been sightings in several different states and countries. Although I would agree, it is much more fun to fly than paint. I don't condone this behavior...... If my 8 was a flying machine I'm sure I would feel different....LOL
Tell Vlad I said HI. Thanks for sharing your experience it truly helps us all.
Rich
cyberpilot10
Plant City, FL
RV 8 Emp.
Old 02-29-2012, 06:40 AM
tkatc's Avatar
tkatc tkatc is offline
Rich,
Thanks for the kind words! I agree 100%. I tell him almost DAILY to get some paint. It was cute for awhile but now I am getting embarrassed when I park next to him. Everytime I mention it he goes straight to the beer fridge instead of coping with the pain!!
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 02-29-2012, 09:09 AM
Av8torTom's Avatar
Default Hey
Tony - congratulations on your successful first inspection... did you find my swiss army knife when you pulled the interior???
When are you gonna start building?
T.
N677AT reserved
Superior XP O-320, 160HP
Old 02-29-2012, 10:52 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Default flap motor and rod end?
I was just noticing in the picture of the interior opened up for inspection that the flap motor panel covers were still on. Did you have an opportunity to bond with that part of the airplane? It can cause grief if the safety wire that prevents unscrewing of the rod end is not installed or has come loose.
Looks like a great experience and an opportunity to have lots of eyes on the plane. Congratulations!
All Best
Jeremy Constant
Old 02-29-2012, 02:20 PM
Pilottonny Pilottonny is offline
Question
Originally Posted by tkatc View Post
............... Here he took a close up picture of a linkage that should have a washer installed............
It looks like it has something to do with the fuel injection, but was is the linkage and controls for?
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 02-29-2012, 03:20 PM
tkatc's Avatar
JJ,
I did end up taking the flap motor panel covers off but had taken the picture first. Good catch. Yes, I am bonding with the plane more and more. Spent a few more hours putting things back on and I am nowhere near close to having it ready to fly.
Tonny,
It is the purge valve linkage that allows me to recirculate cool fuel into the hot lines to aid in starting a hot fuel injected engine. It seems to work very well. I have actually been thinking wether or not that washer is actually required though...that control is only used for starting and is not a "flight control". I will add the washer as recommended but I am thinking it isn't really necessary when you reflect on what the control is used for.
Track my RV7A!!
Old 03-01-2012, 12:43 AM
kiwipete kiwipete is offline
Default Can it stop the engine?
Tony
I guess the answer to the post about the washer is, can it stop the engine if it breaks? Also I noticed the control arm looks like aluminium which would be far more prone to fatigue and possible cracking so maybe a steel replacement.
Or alternatively have a spring that holds it in the correct position if the linkage breaks.
Peter
RV7 G-PBEC Flying
RV10 Finishing
Old 03-01-2012, 06:42 AM
tkatc's Avatar
Peter, there IS a spring that holds the valve closed should anything break. The more I think about it, the more I realize the entire linkage is a non issue.
Track my RV7A!!
Old 10-26-2012, 05:55 AM
Vlad Vlad is online now
I am placing tube$ & tire$$ order with ACS and want to replace brake pads also. What item numbers are those lining kits for RV9?
http://www.aircraftspruce.com/catalo..._brklinig2.php
Old 10-26-2012, 06:42 AM
tkatc's Avatar
Order here dummy!! Support the advertisers!
http://www.vansaircrafttires.com/
Track my RV7A!!
