I am very interested in an RV4 that has this old engine. I called lycoming and the serial number is from a 1965 IO-320-B1A.
The logs start in 1996 at the SMOH time of zero. Then there is a 3 year gap (correction..7 year gap). Then it was run for 240 hrs in an RV6 when it was transplanted into an RV4 in 2010. At that time the fuel injection was removed and the sump changed. The latest owner added a pair of Pmags and has flown about 80 hours.
I am telling myself I should probably avoid this one, but I am not experienced enough to know if I am being silly. I don't know the story of the first 30 years of this engine's life. Still, it seems to have been thoroughly inspected and rebuilt to lycoming tolerances in 1996, so it should be good right?
I attached the log below. The images are in page order. The first 2 images are the top and then bottom half of page 1. On the second to last page I covered the N numbers of the aircraft. Neither have been in a reported incident (no noseover / no prop strike).
I figured this is the best place I can get some tallented opinions to help me decide.
Thanks! This should be fun!
