02-09-2012, 06:49 PM
propeller spinner bulkhead cracks
02-09-2012, 07:32 PM
I would suspect the main culprits to be vibration and fatigue. As soon as one of the supports cracks then the others will follow quickly as they are now overstressed from the lost support of the broken mount.
I would suggest you get the prop balanced as this is a telltale sign of excessive vibration. I would aslo look closely at your baffling and exhaust system, these are also very succeptable to excessive vibration.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-09-2012, 07:57 PM
Thanks Walt. It was dynamically balanced 400 hrs and 2-1/2 years ago...how much do these thing change? Thx, -Jim
02-09-2012, 08:14 PM
Did it take a lot of weight, and is that weight attached to the spinner bulkhead?
Dan Horton
RV-8 SS
Barrett IO-390
02-09-2012, 08:26 PM
Dan, I don't remember how much weight. Screw, nut, and a couple washers? I can remove and weigh in a couple days. Yes, attached to the spinner buikhead flange. Whatcha thinking? Thx, -Jim
02-09-2012, 08:55 PM
How old is the spinner and what aircraft is it on? How many hours on it before balancing?
02-09-2012, 08:56 PM
engine prop balance weights get bolted to the starter ring gear. Spinner back plate cracking is most likely due to centrifigual forces from the spinner not being perfectly centered.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
02-09-2012, 09:09 PM
Unsure of exact age...could go back to '66 since it's on a V35 Bonanza.
Are you thinking just old age fatigue in this case?
Thx!
-Jim
02-09-2012, 09:11 PM
I'm trying to visualize the ring gear on the -540 for the RV-10...where would it bolt to? Drill a new hole? Guess I'll have to take another look when I return from this business trip.
Thx!
-Jim
02-09-2012, 09:25 PM
Is there a lip (or step) at the cracks?
If so, it could be that the metal "ring" was not a tight slip fit and the bolts stressed the material when the bolts were tightened up?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
