02-09-2012, 05:11 PM
Corrosion due to manufacturer's markings
I have noticed that on my aluminum skins I have gotten corrosion where the markings applied by Alcoa were printed.
Any suggestions for dealing with this? I suppose I need to lightly sand the corrosion off and treat it with some kind of primer or corrosion inhibitor. Any suggestions? I am not planning on painting the surfaces anytime soon, but am getting close to a first flight and streaks of rattle can zinc chromate would really look strange.
Thanks.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
02-09-2012, 05:41 PM
hmm
are you sure it is corrosion? Try wiping it with mek. If in fact it is corrosion then you will have to scuff it with scotcbrite and treat it with alodine or self-etching primer. I have never seen anything like that. If you are planning on painting in the near future, you may not have to do anything and take care of that at painting time.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
02-09-2012, 08:45 PM
Some time before I began my project I built one of Van's practice toolboxes and tossed it into a corner of my garage. As I geared up to build I fetched the toolbox and was surprised to find that the marking ink had promoted corrosion under the ink. I believe it is absorbing water from the atmosphere. So, I was careful from day 1 to clean all that ink off my airplane parts.
-Andy Turner
RV-10 N784JC
02-09-2012, 09:04 PM
corrisive inks
I know that inks can be corrosive. For example, some pens have chlorides in them and can not be used on stainless steel, else they cause chloride stress corrision cracking. The nuclear industry is very particular what marking pens can be used/not used.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
02-10-2012, 07:37 AM
I noticed that as well
On some of my parts, the blue ink was causing corrosion. Early on in my build I wasn't worrying about wiping off the ink until I found this out. After I made sure to wipe off all the ink.
Randy
8A flying
02-10-2012, 09:14 AM
I've noticed the opposite.
A very light tarnish on the sheets, but still shiny under the blue markings when the ink is removed with acetone...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
02-10-2012, 10:14 AM
Corrosion in Arizona?
I don't think you or I know what corrosion is....... living in the desert southwest like we do
My experience is just like yours, shiny underneath when cleaning off the blue markings.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
02-10-2012, 12:51 PM
Yep... but I saw the same when I lived in Los Angeles a mile inland from Marina del Rey. It just happened a lot quicker...
Gil Alexander
02-11-2012, 07:02 PM
Is it corroded or etched?
I've experienced the same thing, Jeff. Many of my parts which were stored for 2+ years with the blue plastic still on revealed "corrosion" where the lettering was. That is, I'd remove the blue plastic, clean off the ink with lacquer thinner, and find the lettering still there, in the form of a different shade of aluminum color (not as shiny)! It almost looks like the top layer of (pure) aluminum of the alclad is gone, but I wouldn't know. I took a sample to a couple of local A&Ps for their assessment. They said they didn't think it was corrosion, but rather etching. Neither thought it was anything to be alarmed about, said it shouldn't get any worse now that the ink is removed, and I can ScotchBrite and prime those areas if I'm particularly bothered by it.
I believe Van's recommends removing the blue plastic immediately upon receipt of the parts. Maybe for this reason?
Shannon Miller
RV-7A Fuselage
