Old 02-09-2012, 09:40 AM
sbalmos's Avatar
sbalmos sbalmos is offline
Default Dimpling pre-formed HS - Okay to bend open skin?
I may be over-thinking or over-worrying. I'm about to dimple my -9a's HS skins on my DRDT-2. It started me thinking of how the DRDT-2, or even any conventional C-frame, is supposed to fit inside the skin if it's got a pre-bent leading edge?
Reading around some *really old* (circa 2003-2005) forum entries via Google, it's apparently safe to bend open the skin? To the point where the other side of the skin is bent open 90 degrees? And the skin will still be springy enough that it will snap back after I remove it?
I guess I'm worrying too much that bending the skin open (to basically "insert" the DRDT-2) would remove the pre-bent leading edge, and leave the skin permanently bent open.
Thanks for any confirmation and easing the worried mind.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 02-09-2012, 09:49 AM
flytoboat's Avatar
flytoboat flytoboat is offline
I tried that and got some minor deformation. I suggest pop rivet dimple dies for those holes.
Don
VAF #1100, EAA864
-6A bought flying
Old 02-09-2012, 10:17 AM
sbalmos's Avatar
Thanks Don. I was starting to wonder that might be the case. Let the DRDT-2 do the ones it can reach without too much bending (maybe about half?). The rest, just pop dimple.
Time to place another order with Avery.
Old 02-09-2012, 11:16 AM
pilotian's Avatar
pilotian pilotian is offline
Default My personal opinion
From my recent experience (yesterday) I had my step dad bend the skin back to basically 90 degrees and was finally able to get those tought holes. I learned not to be to affraid of pushing the skin back while doing it and I dont see any type of deformation on mine or lack of "springy backnous". I deem it safe to do!
Ian Hoyt
N527DH (reserved) RV-8
Tail Kit: 80% done
Website:
Follow my flying journey on PilotIan.com
Twitter: ianhoyt
Old 02-09-2012, 12:24 PM
WenEng WenEng is offline
Default Get the pop rivet dimple.....
There are many places where the pop rivet dimple makes your life much easier. Order the 3/32 and 1/8 set. After you practice you will find you can do many dimples without snapping the nail. Even then you can use standard finish nails to keep on dimpling. The trick is not to think you are setting a pop rivet and pull so hard. Beautiful dimples are made without all that nail breaking pressure.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 02-09-2012, 12:50 PM
MarkW's Avatar
MarkW MarkW is offline
Scot,
Bending the skin back is fine. IF. If you are careful not to kink the bent back portion. It should be pulled back evenly across the entire skin. The biggest mistake is to have the thing sprung open and then not get it flat on the dimple die. If it is not flat then it will create a bad looking dimple. My right (second) side turned out much nicer than the left. I ended up building a 90 degree jig to hold the skin. It was very useful for the stiffener back rivet portion as well.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 02-09-2012, 01:06 PM
randyintejas's Avatar
randyintejas randyintejas is offline
Default Also highly recomend
one of these..
https://www.cleavelandtoolstore.com/...mber=DIE4263DF
you can send me a thank you check ($$) latter!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-09-2012, 01:35 PM
rv9aviator rv9aviator is offline
Not the same part but you can bend the skins back with no problem.
The top skin is held back with duck tape.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
