Old 02-08-2012, 07:19 PM
Jermechanic's Avatar
Jermechanic Jermechanic is offline
Cool Replacement toggle switch EXP-2V-Toggle 10
Out flying in some cooler weather and found my instrument light switch on my EXP-2V-Toggle 10 panel (Exp-Bus DC Load Center) was stiff. Gave it a little too much pressure and the switch seemed to have let go- doesn't work anymore and doesn't feel right. I would love to have a replacement switch on hand before I pull the panel apart. Any one have one of these panels I can get a picture of the switches. I think it will be a SPST switch- I was thinking a Cole Hersee 5582 might be a replacement?
http://www.colehersee.com/home/item/cat/33/5582/
Thanks Jeremy
Jeremy Prpich
C-GJZI RV6 Slider
Home base CYYJ- Victoria Int'l
Old 03-20-2012, 11:10 AM
Default 5582 Does work as a replacement
Cole Hersee 5582 Does work as a replacement
Jeremy Prpich
C-GJZI RV6 Slider
