Old 02-08-2012, 05:32 PM
rwarre rwarre is offline
Default Wiring question
I am hooking up a King KI-206 to my Garmin 430. The wiring diagram calls for pin 21 (Main +Left) on the P4001 connector to connect to pin N (underlined) on the P2061 connector of the KI 206. The diagram also calls for the pin 5 (Vor/Loc +Left) on the P4006 connector to connect to the same pin N on the KI 206. Should I connect just one of the wire to the ki 206 or connect both wires together and then to the ki 206?
Old 02-08-2012, 06:40 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
NO, there is a Note at the bottom of my Installation Manual schematic that says "lower case pins references are shown in Upper case with an underline" or words to that effect.
So "N" is actually pin "n"
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-08-2012, 06:49 PM
Walt's Avatar
Walt Walt is offline
Underlined means small 'n' which goes to pin 21 the way I see it.
Looks like Gil beat me to it!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
