Old 02-07-2012, 03:48 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Question AN fitting help
Ok, need some help finding a part/ part number. Looking for a 90 degree bulkhead fitting. Cockpit side is -6 and firewall side is -4.Both flared tube. The one I have is a straight fitting, but a 90 degree would work so much better.
Is there such a beast?
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
Old 02-07-2012, 04:07 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
http://www.gen-aircraft-hardware.com/
Poke around on Toms site, be sure to click on the tech info, the symbol that looks like a wrench.
If it exists, it will probably be here.
You could also send Tom a PM, here is his contact info.
http://www.vansairforce.com/community/member.php?u=5077
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-07-2012, 04:10 PM
Cool If I can ask-
What are you using it for? might be easier to change the hose end.
Tom
Ridgeland, SC
Old 02-07-2012, 04:18 PM
randyintejas's Avatar
randyintejas randyintejas is offline
He does have alot of really great stuff but, his site is really hard to use.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-07-2012, 04:19 PM
C-FAH Q's Avatar
Default Smoking
Tom
It's the bulkhead fitting for the smoking airplanes system. It's a -6 hose inside the cockpit, and a -4 from the bulkhead fitting to the injector. I could split the hose and install a barbed fitting, but prefer to do it with a bulkhead fitting if possible.
Here is a link to a post that shows the pic of an installed barb fitting, the bulkhead fitting will keep it tight to the firewall and look tidy.
http://www.vansairforce.com/communit...king+airplanes
Gary Wilcox
RV7 Sold
C-FAH Q now N281CT
Old 02-07-2012, 06:13 PM
terrye terrye is offline
Default Bulkhead fitting
A reducing bulkhead fitting (90 degree or straight) does not exist in the AN8XX and AN9XX series. The AN919 reducer is as close as you're going to get with a store bought fitting, but this lacks the bulkhead nut. If you know a machinist you could get a custom fitting made, although the 90 degree end would be costly. A straight bulkhead reducer would be cheaper. Or you could get an adapter made with a flange and smaller body drilled through and tapped the appropriate NPT size on each end. The flange gets riveted onto the firewall and you screw in an AN822 (Elbow, flared tube and pipe thread 90 degree) on one end and an AN816 (Nipple, flared tube and pipe thread) on the other end.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 02-07-2012, 07:00 PM
GAHco's Avatar
GAHco GAHco is offline
Default 2 peices
Corrected post.
AN833-6D and AN894-6-4D (Corrected) with a ms28778-6 o-ring. This is if you need the bulkhead feature. Maybe some bulkhead nuts if you need them.
Do not torque the AN894-6-4D as it seals at the base with an o-ring.
You could also use an NAS1564-6-4D held on with an818-6D B-nut.
http://www.gen-aircraft-hardware.com.../pdf/ftg37.pdf
If you do not need the Bulkhead feature, use an AN919-6D
http://www.gen-aircraft-hardware.com...f/ftgadapt.pdf
I hope this helps.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 02-07-2012, 08:01 PM
Christopher Murphy Christopher Murphy is offline
Default You need this
AN894-D6-4 if spruce doesnt have it check wicks
Cm
Old 02-08-2012, 02:35 PM
GAHco's Avatar
Exclamation Corrected Post #7
I made some mistakes initially in this thread, post #7 has been corrected.
Sorry if I caused some confusion
Get em in the Sky!
Tom Brink Pres.
Old 02-08-2012, 03:03 PM
C-FAH Q's Avatar
Default Special service
Tom of TS Flightlines made one for me to exactly what I wanted.
Thanks Tom.
Gary Wilcox
RV7 Sold
C-FAH Q now N281CT
