Old 02-07-2012, 08:50 AM
carlrai's Avatar
carlrai carlrai is offline
Default Adding Audio Soundtrack to Video
Making an attempt at editing a few videos and adding audio is a must after removing the drone of the engine from the recording.
No problem adding the audio track but first attempt contains copyrighted (Van Halen - Dreams) music so I can't share it on YouTube without doing some magic that others seem to have a handle on.
It appears that those that are successful using a sound track containing copyrighted material have included the name of the song and artist along with a link to where it can be downloaded. If someone can explain how this is done and anything else necessary that simplifies all the legal issues I'd sure appreciate it.
Boring to begin with - worse without the music. Will post if I ever get this solved. Thanks!
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 02-07-2012, 09:18 AM
mv031161's Avatar
mv031161 mv031161 is offline
forget Youtube unless they allow a song in their list......use Vimeo where you dont have any of the audio copyrights issues.
Here is the last one I uploaded in YT with an allowed audio song ENJOY! http://www.youtube.com/watch?v=eDDHm...1&feature=plcp
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 02-07-2012, 10:35 AM
carlrai's Avatar
Default Primal Fear
Great looking airplane and great video.
I've looked for the list of approved songs you mentioned but can't find it.
Any ideas of how so many videos have copyrighted material?
I'll check out VIMEO. Thanks for the reply.
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
Old 02-07-2012, 11:45 AM
Capflyer's Avatar
Capflyer Capflyer is offline
I've been a little miffed at what the best way is as well but I can tell you that Vimeo does screen for copyrighted music just like youtube. One thing that has worked for my videos so far is to remove the tags from the music file. Right click on the music file and select properties. Select the Details tab and at the bottom you'll see something that says Remove Properties and Personal Information. Not sure if this is the best way to do it but so far I have not had anything kicked back from Vimeo or Youtube when I've done this. I would guess that all the screening they do for copyrighted music is done electronically looking for this information. Perhaps there is someone on the forum with better experience and expertise in this area?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 02-08-2012, 05:29 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
As I understand it, Youtube allows copyrighted music now with only a warning issued to you in an email. In your youtube admin area you will see a "Matched third party content" link next to any video that has copyrighted music in it. When you click on that link, it states the following:
"What should I do? No action is required on your part. Your video is still available worldwide. In some cases ads may appear next to your video."
The only limitation with this warning is that you can't monetize (run your own google adsense ads) on the video. Youtube displays where people can buy the music soundtrack and has it's own adsense ads on your video when people watch the video. This way, Youtube and the owner of the music make money.
Here's an example of a video I just uploaded. Any ads that are displayed aren't mine.
Steep Turns in a Cessna 172 using the Drift HD170
Smitty
Old 02-08-2012, 10:43 AM
carlrai's Avatar
Default My audio was removed by YouTube
When I tried uploading the first time, YouTube did post my video but removed the audio, a Van Halen recording. The note I received wasn't anything like what you've described. I've since removed the video and the message is gone but it was something to the effect that it was copyrighted material and couldn't be used.
I'll try again but I expect the same results. I'm obviously doing something different.
It's a real puzzle to me how so many others contain the audio from music files. Looks like I'll just have to share with friends locally without uploading to public view.
Sure wish someone had a definitive answer.
Thanks for your input.
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
Old 02-08-2012, 11:22 AM
SmittysRV's Avatar
The other part I left out is that Youtube negotiates with artists about allowing their stuff to be used so they both can make money, like I mentioned earlier. Some artists just flat out refuse to allow any use of their music. I would think that the more well known the artist, the less chance of getting your video posted. Some artists like the idea of free advertising their music by Youtube, so that's the type of music artists to look for.
Smitty
Old 02-09-2012, 05:48 AM
mv031161's Avatar
Mine are open to public!
Mitch V.
