Old 02-06-2012, 12:17 PM
HighSchoolBuilders HighSchoolBuilders is offline
Default To countersink or not to countersink.....
Hi everyone!
I am working on my RV-8 Fuse...
The instruction (Pg. 8-31, Para 4) wants me to Machine Countersink the F-802D-L-1 & R-1, to accept dimples #19 screw hole on the F-820L-1 & R-1 side skin. I find the F-802D-L-1/R-1 is too thin to be machine countersink for #19 dimple, but too thick to be dimpled. I can't countersink as per the instruction without enlarging the hole.
Hope someone can answer this...thanks!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
Old 02-06-2012, 03:45 PM
bird's Avatar
bird bird is offline
Default here it is
Cleco the 802s spacers and 802d box plates to weldments and bulkheads, then machine countersink the screw holes in 802d. The spacers behind it will keep the countersink centered and make a good countersink. Directions tell you to cleco them that way back on pg.8-17 4th paragraph down. I think it also says to machine counter sink with them installed on the airframe too but can't find it right now, it may be on the dwg itself. happy building!
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 02-06-2012, 05:01 PM
Default THANK YOU!
Thanks Bird! I wasn't sure if I am suppose to countersink the hole bigger than the pilot hole, but if the manual says so, it's good to go, thanks!
Hank Cheng
