Originally Posted by Zero4Zulu
It depends on what all you need to pass through the firewall.
I have a 540 and I have one 1" completely full and the other 1" is about 3/4 full. This is probably only four more wires than the typical EFIS implementation for a 360.
You put one layer of the firesleeve through the hole with the wire, so you'll need to allow room for that. You can always fill in any gaps with the sealant that comes with the kit. I'd opt for the larger size.
bob
