02-06-2012, 10:29 PM
Having one I can live with...
About 15 years ago I built a 28 w x 40h x 10ft high ceiling with a 9 x18 ft heavy Kinnear 6 panel door.
6" studs Insulated, dry walled, heated with 5 decent windows.
The only pictures I have are toward the end of this.
http://www.gen-aircraft-hardware.com...Plane_proj.asp
02-06-2012, 10:37 PM
Originally Posted by DMFenster
Washer wrenches - now that cracked me up.
For me - insulation in the walls with pegboard over it to dampen the noise. More light than you would ever think is necessary. A 42" TV - And a great sound system.
They are great. Especially for assembling the control columns. The wrench is thin spring steel. The washer snaps into the end and you hold it in place while the bolt is pused through.
http://www.averytools.com/prodinfo.asp?number=23800
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
02-07-2012, 01:51 AM
I started with a garage that had unfinished bare stud walls. By far the smartest thing I did was to insulate and sheetrock the walls. It's much cooler in here in the summer, and much warmer in winter. Having a comfortable working environment can't be overrated! Here's the "before" picture. You can see that I also added a lot of electrical outlets. Another wise choice.
After the insulation and sheetrock, I painted everything white to brighten it up, and installed a good number of flourescent lights. This has all contributed to an environment that's comfortable and conducive to getting a lot done, even in the middle of winter or the hottest days of summer.
Oh, and I totally agree with getting some washer wrenches. They are a MUST HAVE item!
More pictures and discussion here:
My SHOP page.
02-07-2012, 07:24 AM
Air Conditioning
Already had good lighting and insulation in my basement shop. But it would still get uncomfortably warm during Alabama summers. Less than $200 at Lowes fixed it. I kicked myself for not doing it sooner.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
02-07-2012, 08:32 AM
My new shop has a few upgrades I love
I located my air compressor in an adjacent room that is insulated.
Added wall and overhead air fittings throughout my workspace with coil air hoses.
Added insulated garage door.
Added a dedicated computer with nice speaker system for music. Pandora is the greatest!
Here is a photo from last year....
02-07-2012, 10:53 AM
Sean..
Is that a basement? IN FORT WORTH?
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
02-07-2012, 11:01 AM
I can understand about the washer wrenches. You don't know how many curse words they will stop until you have them. You also need a set of forceps too. :-)
That overhead crane is way cool too.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
02-07-2012, 11:34 AM
My latest upgrade
I recently upgraded the shop with heat. I hope it speeds up my stalled progress on the plane.
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
02-07-2012, 01:32 PM
Yes it is.....sorta
Gary - My garage is basically a walk out basement, and the house does have a basement. Very rare here I know. Here is the best part.....when ist 104F outside its 78 in here; when its 30F outside its 60-65 in here.
I have no heat or AC (in the garage). As long as my wife doesnt open the garage door for something I am basically climate controlled! I also designed that I will be able to finish my 10 fron spinner to tail strobe in the garage before having to move to a hanger.
02-07-2012, 01:46 PM
Below Zero outside, but shirt sleeves in the shop. comfort makes for more productive work sessions
