If you lightly play with the drive gear while the pin is in you'll notice almost a tooths worth of play. Don't use much turning force while pinned and, of course, after seating the mag don't rotate it or the prop before pulling the pin. Also, to get any kind of accurate timing you have to set the mag then back the prop and bump it forward for the break. Otherwise by trying to turn the mag to the timing light the accumulated slop will get you.
Actual repeat offender.
