02-05-2012, 05:35 PM
tried bleeding my brakes today.......
After reading threads via the search on vaf I attempted bleeding my brakes today and failed. I bought a oil pump can and clear plastic hose. I pumped enough oil throug. Whyh the tube to get the air out of the line and then connected the tube to bottom of the brake. I then tried pumping the fluid in but could not. The fluid would not go in. I tried both brakes and the same thing... Also I took the bolt out of the master cylinder. am u missing something here..why couldn't I pump anything in ..
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
02-05-2012, 05:42 PM
Sounds like you took the master cylinder caps off. Did you crack loose the nipple your trying to pump through, takes a ?? box wrench if memory serves. If you did those two things it should take fluid.
02-05-2012, 05:45 PM
Just starting with the obvious Ryan, did you hold the top hex nut with a wrench while unscrewing a 1/4 or 1/2 turn the lower part of the nipple in the wheel break cylinder? Once it is loosened, then you don't need the wrench to hold the top portion of the nipple.
The bottom part of the nipple is what opens and closes the fluid flow. Don't remove unscrew the whole part
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
02-05-2012, 05:51 PM
Also, ensure that the master cylinder rods are fully extended. Even being pushed in an eighth inch will lock out the fluid.
Actual repeat offender.
02-05-2012, 05:52 PM
Brakes
If you have the master cylinder cap off and the small zert fitting cracked open and still cannot move fluid, pull back on or shake each of the rudder pedals to make sure the valves are open.
Pat
02-05-2012, 06:30 PM
One thing to consider.... It is almost impossible to get all of the air out of the low pressure side of the system. A bubble there isn't a problem.
What you can't have are bubbles in the high pressure side.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
02-05-2012, 08:04 PM
Thanks guys...from the responses I think you have fixed my problem. I did not loosen the nipple the crack the cylinder. should go well my second try out it with that info...
Ryan Allen, CFII
E-170/175
02-06-2012, 08:51 AM
Plastic pump sprayer
A small plastic pump sprayer from Lowe's works good. Attach the hose to it, pump it up, hook it up and release the flow.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
02-06-2012, 09:20 AM
Get the bigger chemical sprayer. The reason is that if the pump is in the brake fluid, it will pump air bubbles into the fluid and all you will do is add fluid and air to the brake system.
Just ask me how I know.
In the end, I used a two gallon sprayer like this. Cut the plastic wand off just behind the tip, heated it up and slide one of these into the end of the wand. I then slipped some nylon tubing over the other end and used that to fill my brake system.
With the valve on the tank, it makes filling it really easy.
On the other end, I bought a brass fitting to screw into the top of the brake reservoir and connected it to a one man brake bleeder kit to catch the excess fluid.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
02-06-2012, 01:27 PM
This is what got me. I just did this a couple of weeks back. The fluid would not fill the lines. Then I pulled the master cylinder all the way back to full extension, and the fluid filled in a just a couple of minutes.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
