02-05-2012, 09:33 AM
EGT/CHT Spade Term.
The sensor kit that came with my Dynon 180 came with female spade terminals on the wires of the CHT/EGT sensors. My problem is there are no male spade terminals in the accessory pack which has all kinds of additional connectors.
The female ends are a different plastic than I find on the aviation grade connectors I have bought from Stein. I have to get some of the male spades but not sure if there is anything special about these connectors. I would think connections made and the metal used would have an effect on the thermocouple accuracy.
So can I use a normal aviation grade spade connector to terminate the J and K wire to the female connector on the sensors?
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
02-05-2012, 09:41 AM
Senior Curmudgeon
You might contact Dynon, and see if they have the matching halves available.
If, as I suspect, these are millivolt generators like in a furnace, they are quite sensitive to good electrical contacts for accurate information/readings.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-05-2012, 10:34 AM
You should have gotten them with the FD180 and associated sensors. I'd call Dynon.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
02-05-2012, 12:58 PM
Yes, double the wires over before you insert in the crimp connector, then use a good crimp tool.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-05-2012, 01:31 PM
Will Call Dynon
Thanks for the info, hopefully Dynon can send them to me, I am in the same state so it should not take long to get them. I will call them on Monday.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
