Old 06-05-2006, 11:32 AM
N941WR's Avatar
N941WR N941WR is offline
Default Neoprene or EPDM Rubber?
I need to buy some #8 "rubber" washers to protect my instrument panel paint from the screws that secure it in place. (I have an Affordable Panels panel.)
What is the difference between Neoprene and EPDM Rubber and which should I order?
Thanks for the help.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-05-2006, 11:57 AM
tomwebster's Avatar
tomwebster tomwebster is offline
I tried rubber washers, but didn't like the
way they stuck out, (too thick).
I used white Delrin washers on the light
colored part of my panel and clear plastic
washers where white didn't look right,
(black sub-panel).
I also waited until the paint was dry and
seasoned so the washers wouldn't stick when
put under pressure.
I also have an 'Affordable' panel and the
washers are all available at McMaster-Carr.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 06-05-2006, 12:24 PM
Vern's Avatar
Vern Vern is offline
Default panel washers
Spruce has very thin stainless and also white plastic washers that work well for this application.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-05-2006, 02:19 PM
N941WR's Avatar
Thanks guys but neither solution will work for me.
My panel is dark gray and I'm using black cap screws, thus the desire to use black washers. The only question is which ones, Neoprene or EPDM Rubber?
BTW, after my panel dried, I baked in the oven for 2 hours at 200 degrees to cure the paint and when I rememoved the cap screws, I still removed some of the paint.
Bill R.
SC86 - Easley, SC
Old 06-05-2006, 02:39 PM
RV8N RV8N is offline
I'm not too sure either one is going to work. Neoprene and rubber are pretty sticky... I think they will stick to the screw and panel and just ball up. I used the opaque white plastic (nylon?) in most places and think it looks good... better than messing up the paint under the screws.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 06-05-2006, 03:34 PM
chaskuss chaskuss is offline
Originally Posted by N941WR
snipped
EPDM stands for Ethylene Propylene. This material is used for automotive brake parts, as it best resists automotive brake fluids (glycol esters) It's working range is -35F to +300F.
Neoprene was the first synthetic rubber developed. It is a "general purpose" compound. You can find out more about it here.
http://www.baxterrubber.com/neoprene.html
For more on EPDM go here
http://www.acmerubber.com/epdm.htm
Either compound will work, however, I think Neoprene has slightly better compression set characteristics, so I'd choose it.
Charlie Kuss
Old 06-05-2006, 09:24 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Dyes
One option might be to dye natural colored (whitish) nylon washers.
Nylon reponds quite well to RIT dye from your local department store.
You could see if black dye would make the white nylon washers dark enough.
Mix the dye to a stronger solution than on the box...
If it doesn't work, just use the left over dye to make some trendy 60's tie-dyed T-shirts...
gil in Tucson
PS This also works well to color code PVC tubing used for static/pitot applications.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-06-2006, 09:26 PM
N130WN's Avatar
N130WN N130WN is offline
Consider very thin SS washers from McMaster. Same size the the head of the cap screw. Though a different color, should be nearly invisble when installed. I can't see them on my panel.
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
