Old 02-03-2012, 02:20 PM
Av8torTom's Avatar
Default All you LED Gurus...
Any reason something like this couldn't be used for a landing light and/or strobe light?
http://www.luminus.com/products/data..._Datasheet.pdf
Looks to be:
3.5 forward voltage
9 amps
35 watts
2250 lumens
$26
N677AT reserved
Superior XP O-320, 160HP
Old 02-03-2012, 04:58 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
That looks like a very interesting module. The cree modules are over 1200 lumens and they are like looking at the sun!
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 02-03-2012, 05:19 PM
Greenley's Avatar
Greenley Greenley is offline
I have been looking at these and the Cree cxa21011 which are even brighter. Trying to figure out what all would be needed to put two on each side on the duck works blank mounting plate.
Bill Greenley
My RV-10 is now travel, watch out world!!!!!!
Old 02-03-2012, 10:36 PM
mculver's Avatar
mculver mculver is offline
Wow! That is a pile of lumens. But what matters is putting the light where it is needed, and that generally means a parabolic reflector.
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 02-03-2012, 11:03 PM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
This may be great for a Wig-Wag setup.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 02-04-2012, 06:08 AM
Av8torTom's Avatar
Default Reflector
Mike,
I agree with you. The LED does have a lens and there are some data showing what look to be light patterns, but I don't know enough about this stuff to be able to fully interpret. Certainly they should be useful as strobes or wig-wag lights. I think the 9 amp current draw will be a challenge. I'd like to hear from the EEs on the forum.
Tom
N677AT reserved
Old 02-04-2012, 06:39 AM
BillFear BillFear is offline
Default I have been playing with some for a few weeks
3 issues
1) You have to control the current (controller or resistors)
2) You have to heat sink them so they do not get too hot.
3) You have to use a reflector to focus the light.
http://www.vansairforce.com/communit...ight=mr-16+led
Also, good information here at a US supplier.
http://www.ledsupply.com/
Probably the best way to go on the controller is at the bottom of this product page but it will not do the power your mentioned LED wants.
https://matronics.com/aeroelectric/C...ECcatalog.html
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 02-04-2012, 07:42 AM
dpansier's Avatar
dpansier dpansier is offline
Take a look at this LED set up, all I can say is wow.
http://www.candlepowerforums.com/vb/...more-beamshots
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 02-04-2012, 09:36 AM
Av8torTom's Avatar
Default WOW
D,
Yeah, one of those would work... LOL
Problem is he's drawing 13 amps. He could hurt himself with that
N677AT reserved
Old 02-04-2012, 09:47 AM
Av8torTom's Avatar
Default Reflectors
Bill,
Thanks - reflectors are available, but I'm interested to see what the lens alone does. The unit looks to be 1 cm square which is pretty small. Maybe I can find ones that draw less current and use several. I may just have to buy one and fool around with it. I haven't found a 9 amp CC power supply yet, but they should be out there.
N677AT reserved
