Old 02-03-2012, 10:48 AM
Echo Tango Echo Tango is offline
Default Single favorite tool?
What was the one tool that you bought during your build (or build in progress) that really made you say WOW! This thing is great! Not necessarily your most-used tool or most expensive tool, but the one tool that you really admired for doing its intended job so well.
I'm still working on my HS so I don't have much experience to speak of, but I've been really impressed with my air drill.
CP7300 Reversible, Keyless Chuck by Chicago Pneumatics
powerful, light, easy on the wallet, and the trigger is butter. Bit changing takes 3 or 4 seconds. Love it
Think I paid around $130 for it.
Old 02-03-2012, 10:55 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
It just might be this sorting tray from Harbor Freight. I have several and use them to store the bits and pieces of separate small tasks going on simultaneously.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 02-03-2012, 10:57 AM
jbagley's Avatar
jbagley jbagley is offline
I got some hole finders in a pile of tools I picked up from a local builder. Didn't know what they were until that one day I was trying to figure out how to find that hole under that sheet of aluminum and drill to match. Simple and effective tool:
http://www.browntool.com/Default.asp...,ProductNumber
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 02-03-2012, 11:25 AM
Rupester Rupester is offline
Default without a doubt ...
....my Cleaveland tool rivet squeezer ... the "Main Squeeze". Incredibly well designed and works flawlessly. And you use a rivet squeezer throughout the duration of the build, be it riveting, dimpling, or other. (...like flattening out dimples you did the wrong way )
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-03-2012, 11:30 AM
im still considering buying one of these. i just purchased my hand squeezer and dimple die set so i imagine it will take me a while to get "frustrated" with it enough to pull the trigger on something bigger and badder
Old 02-03-2012, 11:37 AM
ppilotmike's Avatar
Default Rivet Removal Tool!
Without a doubt, the rivet removal tool from Cleaveland.
http://www.cleavelandtoolstore.com/p...sp?number=RRT4
While you can always drill out rivets by hand (which I do for flush rivets), you can't beat the rivet drill out tool for universal head rivets IMHO.
Mike Rettig
VAF Dues Current
Old 02-03-2012, 11:48 AM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Default wow
Most tools did the job expected of them, drills, die cutters, squeezers, etc. One that really amazed me was the cheap belt sander from HF. Just could not believe how easy it was to shape aluminum parts. Could not get by without it.
Dave
M20C
Paul K Paul K is offline
Default One of my favorites
Die Grinder! I find more uses for this thing; cutting, shaping, edge finishing, etc. The quickest way to deburr an edge is with the 1" Skotch Brite wheel. Makes deburring the inside of a hole very fast and even fun.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 02-03-2012, 11:57 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Definitely the pneumatic rivet squeezer! Don't get to use it too much on an RV12, but I hate the hammering sound of pounding a rivet, and the big ones squeeze too hard for me wth the hand squeezer. Always find it amazing to watch it squeeze a rivet so effortlessly.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 02-03-2012, 12:00 PM
AltonD's Avatar
AltonD AltonD is offline
My Sioux air drill.
rivet squeezer from avery. The build is done, but I have the dies for rivetting brake pads. Great tool for this job.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
