TED Transponder Antenna Installation
I am installing a TED Transponder antenna on the belly of my RV-7A for my Monroy ATD-200 Air Traffic Detector. The antenna comes with the pole and ball antenna, rubber gasket, star washer and nut. The question I have should the rubber gasket go on the belly of the airplane or should it not be installed so that the antenna sits flush against the belly to create a better ground plane. Thanks in advance
Reason: Spelling error
