Old 02-02-2012, 04:26 PM
gasman gasman is offline
Default Don't give up on your Hobbs....
The standard Hobbs meter will still be there counting your aircraft hours well after your EFIS or EMS has failed or been replaced.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 02-02-2012, 05:55 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I was debating about putting in a Hobbs, but it isn't very expensive and, for the reason you gave, went on and added it. If one is otherwise lacking in panel space, I don't think it is that big a deal to leave it out, but engine time in an EFIS can be reset, so having a real Hobbs might give some extra credibility when you go to sell the airplane.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 02-02-2012, 06:00 PM
Greg Arehart's Avatar
I did exactly this, Hobbs tied to an oil pressure switch, but have had trouble with the switch or the Hobbs (not sure which, but I think the switch), so it hasn't been as accurate as my Dynon.
greg
Greg Arehart
N 7965A
Old 02-02-2012, 06:23 PM
jbagley's Avatar
jbagley jbagley is offline
I have the same setup as Greg. I found my hobbs runs fast by about 10%. Must be one of those special units used on rentals.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 02-02-2012, 06:33 PM
Lars Lars is offline
Default You mean like this?
Taken a few evenings ago...
Not running (let alone flying) yet, so accuracy has yet to be demonstrated.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 02-02-2012, 07:12 PM
Mel's Avatar
Mel Mel is offline
Remember, it doesn't have to mounted in the panel. I can be behind the panel, under the panel, or even forward of the firewall.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-03-2012, 03:10 AM
mike newall's Avatar
mike newall mike newall is offline
Why....................?
You are not renting it !
I just do not get this Hobbs thing - use tacho, or whatever your EFIS gives you and pay attention to oil changes - the end
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 02-03-2012, 07:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Same for me - the first thing I did when I bought my first airplane (decades ago ) was to get rid of the Hobbs - I needed the panel space, and this was NEVER going to be rented to anyone....it was unconsciously symbolic, I think.
You can cheat the numbers with a Mechancial Tacho, Hobbs, or EFIS BTW....
Just my opinion, of course...do what works for you!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
My "why" was that the Hobbs sits there with numbers on it whether or not the battery or engine is on. At the time of building, I hadn't trained myself to check the times on the Dynon before shutting down, and I could still look at the Hobbs after shutdown and determine my flying time. Of course if its not working properly, all bets are off. So now I'm using the Dynon more consistently for time.
Greg
Greg Arehart
N 7965A
Old 02-03-2012, 07:16 AM
turbo's Avatar
turbo turbo is offline
i would say these hobbs are not what they are cracked up to be. my first one crapped out at 100 hours. at close to 4,000 the next one started acting up so a new oil pressure switch and hobbs installed. now my hobbs reads 40 hours. just like starting all over again except the eis has the correct time. seems like the log books would justify the real aircraft times.
Hobbs
a city in southeastern New Mexico, just west of the Texas border, southeast of Roswell; pop. 30,476 (est. 2008).
Hobbs, Sir Jack
(1882?1963), English cricketer; full name John Berry Hobbs. During his career (1905?34) he scored 61,237 runs and 197 centuries, and made 61 test appearances for England.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
