View Poll Results: How much money in dollars. See criteria below
Zero (ya right) 1 1.05%
1 - 50 14 14.74%
51 - 200 33 34.74%
201 - 500 23 24.21%
501 - 1000 18 18.95%
1001 - 3000 5 5.26%
more than 3000 1 1.05%
Voters: 95. You may not vote on this poll
Old 02-02-2012, 11:05 AM
diamond diamond is offline
Default How much have you spent fixing screw-ups?
So it's common to have to reorder parts that get damaged during the build, right? At least that's the impression I get from years of reading posts on VAF. I'm curious how much extra money is spent, on average, during the course of an entire RV build fixing screw-ups. Here's the criteria for the poll.
1) Interested in money spent for new parts and shipping for your first build only.
2) I'm guessing fewer screw-ups with pre-punched kits, so let's make this poll for pre-punched kits only.
2) Not interested in money spent replacing tools.
3) Interested in slow build wings and fuselage folks who built the entire plane, not purchased partially built.
4) Screw-ups caused by you or anyone helping you in the process of building. Not damaged items caused by moving, dropping, fire, etc.
Old 02-02-2012, 12:36 PM
I'm not building a prepunched model so I didn't vote, but I have probably spent a few hundred in replacement parts I screwed up. I'm not done, but the vast majority of the metal work is.
From memory I replaced (when I couldn't repair):
1 Lower longeron
1 Vertical former in the baggage area
1 Tank baffle
1 Aft upper tailcone skin (the small one)
1 The formed lower part of the rear spar carrythrough bulkhead
1 Wing Rib
1 Aileron Skin (was damaged in storage)
That's all I can remember, but there were probably others that I had the material on-hand to remake myself.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-02-2012, 12:39 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default It's not the $
It's not the $, but the question is the time. How many HOURS did your screwups cost?
I think I am only in for about $30 in parts, and another $45 in shipping
Hours, that is a hole nother story As My task tonight is to drill out about 50 rivets so I can move one piece from in front of another to behind.
Bill
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 02-02-2012, 01:06 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Anyone who has cracked a canopy gets elevated immediately to the big spending category. So one little screw-up can cost you a bundle. If not for that, my replacement parts would be a little over $200, but definitely less than $500.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 02-02-2012, 01:13 PM
200 maximum. Good poll.
Old 02-02-2012, 01:28 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Freight
My parts cost has been under $200.00 However the freight to get parts for one screw up was over $200
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 02-02-2012, 01:36 PM
noelf noelf is offline
*Tip-up canopy just over $1000 including shipping.
*Three elevator trim skins to get one that I was proud of. Shipping cost more than the parts.
* Horizontal stab fiberglass tips because at the time I did not know how to fix fiberglass. Now I do.
Noel
RV-6A N6NF
tip-up
flying
Old 02-02-2012, 02:37 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Where's the option for I dont know...dont want to know...dont let my wife know.
I've messed up several rudder skins...a rib here and there...spar for the hs...a skin for an aileron.
As Bill said...its the time that you miss waiting for the part that hurts more than the cost of the part. The cost of the shipping is just a reminder to be more careful next time.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 02-02-2012, 02:42 PM
AltonD's Avatar
AltonD AltonD is offline
I am guilty.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-02-2012, 02:55 PM
ptrotter ptrotter is offline
I'm convinced that Van's make more money from replacement parts than they make on the kits themselves. I think I replaced one $100 part at least twice. The worst is when you spend $25 to ship a $4 part because it is holding up the building process.
Paul Trotter
Sussex, NJ
RV-8 82080 Finish/FWF Kit
N801PT
