Old 02-01-2012, 03:28 PM
RobinHou RobinHou is offline
Default SL30 vs. GNS430
I came from certified airplane world, and in that planet 430, W or not, is the king (maybe not king, but sure is very very popular).
However, on VAF and other experimental forums, it seems that popularity of SL30 is the same, or more than 430's.
With the introduction of 650, a used 430W is about $4.5K and a used non-W 430 is about $3.3K. A used SL30 still sells for around $3K without GPS and map. For a few hundreds, it seems that 430 (W or not) offers a lot more functions.
What am I missing?
Old 02-01-2012, 03:38 PM
Jamie's Avatar
Jamie Jamie is offline
I don't think you are missing anything. I have an SL-30 and I will tell you that hands-down it is the best NAV/COM on the market. However the 430 still seems to be king and the desired unit.
Where are you seeing used 430w/s for 4.5k? If someone has one for sale for that price please contact me via PM or e=mail!
Old 02-01-2012, 03:51 PM
jbagley's Avatar
jbagley jbagley is offline
Ditto Jamie.
The other reason is to avoid the yearly garmin tax for database updates. The SL30 doesn't have a database.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 02-01-2012, 03:55 PM
flyinga flyinga is offline
It depends on the kind of flying you intend to do. If you are a VFR only local area guy the SL30 will do just fine. If you intend to fly IFR go for the 430.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 02-01-2012, 04:26 PM
flyeyes's Avatar
flyeyes flyeyes is offline
A major advantage of the sl30 is the ability to monitor a second frequency, both comm and nav.
This gives you the functionality of dual nav/comms and an audio panel for much less money and panel space.
Flying IFR with a single 430 requires some juggling to listen to ATIS, etc.
You can even identify crossing radials with the dual monitor function on the nav side, a very neat trick.
I regularly fly two aircraft equipped with G430s and the SL30. There are many factors involved of course (antennae, etc.) but both the comm and VOR function seem to work better on the SL30. Not enough to make a functional difference, but I'd rather use to SL30 for a comm, or to navigate via VOR, then the 430 FWIW
James Freeman
RV-8 flying
Old 02-01-2012, 04:36 PM
I routinely fly IFR in multiple airplanes. Haven't used a VOR in years. The cross radial function is neat but in the real world GPS is neater. I do like the monitor feature of the SL30 for ATIS etc. but if I had to choose one or the other I'd go for the 430. (I've got both in my 8)
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 02-01-2012, 04:37 PM
Subwaybob's Avatar
Subwaybob Subwaybob is offline
I was JUST speaking to Garmin about this. I am going with a G3X system (2 screen) and the SL30. They tell me this is all you really need, even for IFR. I did not know about the "no update" stuff. Now I'm really sold!!!!
Bob
RV-10 QB Here 8-25-19
RV-7
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
Old 02-01-2012, 04:58 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
The 430 gives you a moving map, terrain (W version?), obstacles and GPS approaches that the SL30 does not. You don't get GPS approaches with a 396, 496, etc.
What do you need?
Old 02-01-2012, 05:15 PM
AllThumbs's Avatar
AllThumbs AllThumbs is offline
Default 400W + SL40
My RV-6 will soon have a 400W along with the existing SL40. For redundancy I have a handheld COM and a GPSMAP 496 - both battery powered.
No VOR, ILS, or LOC. Yes, a freak solar storm could cause problems, a star wars attack from China could take out our GPS system, and Light-Squared or our own DOD could run some test that spooks the satellites as well.
But if GPS is good enough for Nextgen it'll do for the rare times I really need to depart IFR or return to KDVO (1000 AGL GPS MDA) or nearby O69 (300 AGL LPV!). I don't want or need the extra antennas, wiring, and complexity. Every airport I want to fly to or from has an RNAV approach now.
Neil
Old 02-01-2012, 05:16 PM
Brantel's Avatar
Brantel Brantel is offline
I beg you to do more research on the subject. Technically yes but there is more to it than that.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
