Old 01-31-2012, 09:24 PM
aeropunk aeropunk is offline
Default Torque Tables for Dummies
Let's assume for a moment that I'm a bumbling idiot and have no idea how to reference a simple table like the one pictured below. Let's assume that I've got a garden-variety AN bolt (let's say an AN3-4A for kicks), and I'm trying to find the proper torque value for it. Let's go a step further, and pretend that bolt is going into a nutplate rather than a nut, and thus I'll be applying the torque to the bolt rather than the nut. Can somebody give me the idiot-proof method for going from an AN-hardware value to the Nut-Bolt size column on the left-hand side of the chart? I've read all the standard refs (AC43.13, Aviation Mechanic Handbook, Standard Aircraft Handbook), and I'm still not making the connection. What am I missing? Thanks in advance!
"When the ships returned from a mission, everybody watched for them. They came lining back
to the field in flights of four, flying tight show formation with the black smoke fading in parallel
streams behind. They seemed to be most indestructible then. They were of frozen silver."
~ James Salter
Old 01-31-2012, 09:29 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
The idiot-proof method is to use the torque table in Section 5 of your plans that Van's sent you. Using your table, though, an AN3 bolt has 10-32 threads, and you'd use the standard torque like you would with an AN365 nut, so 20-25 in-lb.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 01-31-2012, 10:04 PM
terrye terrye is offline
Default Torque
When tightening a bolt into a nutplate or a self locking nut onto a bolt, you first need to note the torque needed to turn the fastener against the self locking feature. Then you need to add this torque to the tightening torque from the table.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 02-01-2012, 05:58 AM
n8zg's Avatar
n8zg n8zg is offline
And unless otherwise noted, all torque values are for dry fit-up. BoeLube / oil / grease on the threads will change the torque characteristics considerably.
Neal George
Navarre, FL
CherokeeJet N9586J
RV-7 N8ZG (all the loose ends)
Continental Aerospace Technologies, Product Support
Old 02-01-2012, 09:11 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Unless you are working on a Lycoming engine - then you lubricate the threads and use this table -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-01-2012, 12:21 PM
randyintejas's Avatar
randyintejas randyintejas is offline
This is where a Dial Face Torque Wrench is real handy!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-01-2012, 02:02 PM
az_gila's Avatar
Smile
...or a cheaper beam type - like this 14 inch drive one from bicycle stores -
http://www.performancebike.com/bikes...AID=1009381503
Gil Alexander
