  #61
Old 12-16-2015, 11:41 AM
Kofficer Kofficer is offline
Default jack stands
I know this is older thread, but my concerns is that the question was never answered about whether or not the threaded tie down point is truly strong enough to push up 500lb. Also, if you do use this point, wouldn't it be better to cut the bolt down to where you could screw the cap all the way up to the wing to not be pushing on just the threads? Could possibley put something between the 1" pipe cap and wing to keep it from scarring up the undersurface?
Old 12-16-2015, 12:19 PM
tmbg's Avatar
tmbg tmbg is offline
WAY strong enough. If I remember correctly, those are AN6 size holes, AN6 has a tensile strength of at least 14,000lb. The stripping strength of the aluminum tiedown will exceed the tensile strength as long as you have 3 diameters thread engagement, which is ~1". The tiedown block in the wing is bolted to the spar with 4 AN3 bolts, which are good for 2100lb EACH in single shear. Remember, the tiedowns are designed to prevent the airplane from flying in a high wind. If it's flying, it's lifting the entire weight of the aircraft. The tiedowns easily handle that.
Ian
Old 12-16-2015, 12:36 PM
maniago's Avatar
maniago maniago is offline
Point of order: If a wind is lifting the aircraft, its lifting at least the aircraft weight, but far more likely to be more as the aircraft is accelerating upwards - ie its in G load. How much? Noone really will ever know except the tie downs.
But the rest of your answer is on point.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 12-16-2015, 11:57 PM
Nice analysis.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 12-17-2015, 09:58 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default not that it matters for jacking load analysis
but at the moment a gust lifts the plane off the tarmac, the load on the tie-downs is ZERO, unless you're pre-loading with a ratcheting tie-down where most of us just use a snug taut-line hitch in a rope.
Correct me if I'm wrong.
Good to know the tie-downs are structurally good-to-go for use as jack-points, though.
-Stormy
Old 08-07-2018, 06:45 PM
jor.ezq jor.ezq is offline
Default RV 10 jack at the wing
My doubt is how long is the jack pist?n in orden to lift the -10
, in the pic, it seems about a feet out and the plane is still on the ground.
Can you see it ?
QUOTE=frazitl;624328]made almost exactly the same as Stephens about 6 years ago for our Mooney.
To solve the problem of attaching the support struts at the top, I found a
ring in the electrical isle at Home Depot with an ID big enough to just
swallow the jack body. I think it even had four flats around the
circumference to attach the strut tops with screws. Anyway, they work
great. I countersunk the top of the jack ram to deepen the hole, and just
use two cut off bolts in the tie down holes to provide secure jack points.
Only improvement I might make is to buy some lock rings available from industrial supply houses like McFaddin-Dale. Probably safer if you ever have to leave the plane on the jacks overnight...
[/quote]
Old 08-08-2018, 07:53 AM
Snowflake's Avatar
Snowflake Snowflake is online now
Originally Posted by jor.ezq View Post
My doubt is how long is the jack pist?n in orden to lift the -10, in the pic, it seems about a feet out and the plane is still on the ground.
Can you see it ?
Note that the nosewheel is off the ground as well. If the nosewheel were lowered the mains would come off the ground with the jacks that far extended.
Rob Prior
Old 08-08-2018, 08:47 AM
JonJay's Avatar
JonJay JonJay is offline
I always jack the plane in flight attitude. This keeps side loading off the jack points. As Rob noted, this should raise the mains on a nosewheel RV.
The only jack point failure I am aware of was use of the wrong type of bolt in the jack point and then a gross side load causing the bolts to bend and shear.
This setup is not right.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 08-08-2018, 01:06 PM
vernon smith's Avatar
vernon smith vernon smith is offline
They put wheels (with castering) under car floor jacks for a reason
Old 08-08-2018, 01:58 PM
Plummit's Avatar
Plummit Plummit is offline
Yeah but when was the last time you saw an aircraft jack with castering wheels....
-Marc
RV-10
N814RV
2020 Donation Made
