01-31-2012, 11:22 AM
Wing skin overlap RV-4
Guys, as I have mentioned before, I am ordering sheet for single piece top skins. However, I will have the 'stock' overlapping lower skins. My skins are not prepunched, which isn't a big deal. Here is my question: What is the skin overlap amount? I cannot find it on the drawings, but it appears to be 1.25 or 1.5". I am asking because it appears that the skins extend slightly beyond the inboard rib for fusemate, and per the drawing, 1/2" beyond the outboard ribs to match the leading edge skin for the wingtip attachment. I need to figure out how long (exactly) to cut my singlepiece top skin. I know the dimensions of both inboard and outboard top skins, so it would appear that I need about 112".
Is it listed on a drawing and I am just not seeing it?
Gregg
Gregg J. Brightwell
Benton, KS
CFII/MEII, ATP, AGI, A&P
-4 Emp and Wings complete!
Fuselage out of the jig!
www.mykitlog.com/gbrightwell
01-31-2012, 11:46 AM
Skin
Hi Greg
Total length of my combined lower wing skins is 111 11/16. The over lap is 1.5 inches.
If I were you I would just use this as a guide. What I would do in your case is measure from the inboard rib to the tip rib, then add 1/2 an inch for the wing tip to sit in. Bear in mind that your ribs wont be perfectly straight and may not be square to the spar so this is chance to square things up a bit.
I any case measure in several places along the rib length, then work to the maximum length you get plus 1/2 for the tip.
Good luck
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
01-31-2012, 01:29 PM
Overhang
Originally Posted by WAM120RV
Hi Greg
Good luck
The -7 kits went to a larger dimension here. Fudging the skin tip overhang a little bit more will make later installation of the tips a bit easier - especially if you go the nutplate route.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-31-2012, 04:40 PM
wing skin length
Gil, I was thinking the same thing. I AM going to go the nutplate route so I can remove the tips later on. I think I will shear them a hair over 112" and leave a bit extra on the tip, and take what I get on the inboard end. I can always remove/file the extra later.
Gregg
Gregg J. Brightwell
Benton, KS
02-01-2012, 02:49 AM
Good advice
Thats good advice from Greg and Az.
A little long gives you room for manouvre.
Steve Arnold
England
02-01-2012, 09:39 AM
Can someone with a RV-7 or RV-8 give us the actual dimension of the overhang on the newer wings?
The new plans don't give actual dimensions for pre-punched parts...
Gil Alexander
