Old 01-30-2012, 09:26 PM
Mike Redd Mike Redd is offline
Default ACS ignition swich repairable, rebuildable?
In the start position, nothing, I checked the relay solonoid and they work when jumped. I think it's the switch or a broke wire ( I doubt) Has anyone repaired the ACS switch from Vans? Can you get just the back half of switch?
Old 01-31-2012, 12:40 AM
131RB 131RB is offline
Mike,
You can pull the screws out that hold it together. Sometimes the contacts get dirty, worn or the springs underneeth them get weak. Chances are good you may be able to just clean up the contacts. I have not had to purchase any but I would guess the contacts can be purchased as separate units from someplace like spruce. Good luck.
Ryan
Old 01-31-2012, 12:52 AM
az_gila's Avatar
az_gila az_gila is offline
Smile AC Spruce
Do you think this will do the job?
http://www.aircraftspruce.com/catalo...nswitchkit.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-31-2012, 03:53 PM
jrs14855 jrs14855 is offline
Default spruce link
The shielding should be grounded at one end only, normally at the mag. The spruce info implies both ends which is incorrect.
Old 01-31-2012, 04:53 PM
Originally Posted by az_gila View Post
It says it comes with the internal contacts so it should be right Gill.
Ryan
Old 01-31-2012, 05:48 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
I used the kit from Spruce and in 20 minutes had a repaired switch. It worked great and was easy to do.
The starter contacts had burn marks on them....turns out, the original builder had a starter with a built in relay but, the instructions say it the starter switch has to be able to take 21 amps. ACS says the switch should only carry 8 amps max so another relay is needed.
How many hours on your switch? Mine went bad after 230 hours. You may also need another starter relay. On the road now but will try to post pics and more info when I get back.
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 01-31-2012, 07:52 PM
alcladrv alcladrv is offline
! also repaired my switch with the Aircraft Spruce part mentioned. No need to put it off. It was simpler and quicker than I thought.
My original lasted 720 hrs.
Mike
Old 01-31-2012, 08:02 PM
Tom Martin Tom Martin is offline
I would repair that switch with two toggle switches
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 01-31-2012, 08:57 PM
Default Acs problem found
I found the problem, when I removed the switch I found the wire to the relay had come loose. Tightned it and all is well. My rv 7 has 825 hrs. This was the first problem with the switch. All the other wires were tight so I may have not tightend when building 9 years ago? Thanks for all the ideas.
Old 01-31-2012, 08:58 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Edit: Disregard this post-I misread the post I quoted.
If you search the forums you will see this is a much argued debate. Bob Nuckoll's argues for grounding shield at both ends in Aeroelectric Connection.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
