Old 01-30-2012, 02:40 PM
jtrollin jtrollin is offline
Default Name this part?
So I was walking around in the garage and saw this on the floor, I have no clue what it is or what it is for. I do not even know if it is part of the plane, but when building a plane in the garage odds are it is a part of the plane.
thanks,
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 01-30-2012, 02:47 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Looks like an insert for a plastic air or fluid line, used at the compression fitting to prevent the plastic from collapsing.
Or, maybe a restrictor for oil or vacuum sensor line??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-30-2012, 02:52 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Same as Mike - brake line?
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 01-30-2012, 03:16 PM
Bavafa Bavafa is offline
Can't say for sure but I think it is a resitrictor for the fuel injection system.
Do you have fuel injector and if so, have you taken the nozzel out either for cleaning for else? Is there a number/marking on this?
If so, your engine should and will not run OK
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-30-2012, 03:26 PM
rocketbob's Avatar
Its an AFP injector nozzle. I hope its an extra!
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Default Looks like we have a winner
Your right, looking at the parts of the injector nozzle it does appear to come from one of them. Now to remove them all to see which one.
thanks,
John - Leesburg VA
RV-10
Phase 1 Complete
798HJ Reserved
Old 01-30-2012, 06:16 PM
Wow, that was pretty lucky. Not only did I find the nozzle, it was missing from the first injector I checked (yes I did check all the other injectors for nozzles as well). I am still surprised I found I found, was able to determine what it was, and fix it. Would not be possible without the great people here on VAF.
THANKS!!!!
John - Leesburg VA
RV-10
Phase 1 Complete
798HJ Reserved
Old 01-30-2012, 06:20 PM
Mike S's Avatar
Senior Curmudgeon
If it has been on the garage floor, inspect it carefully for damage, or debris before installing it back in the engine.
Mike Starkey
VAF 909
Rv-10, N210LM.
