Old 01-29-2012, 11:03 PM
BJohnson's Avatar
BJohnson BJohnson is offline
Default Connecting 16 awg battery bus feed to battery contactor stub?
I need to connect my 16 awg battery bus feed line from the battery side of the contactor to the battery bus. How have others done this? Where do I get a ring terminal that can crimp to the 16 awg wire (or fusible link) that will fit around the stud from the contactor which is about 3/8 inches in diameter?
Or is there a better way?
Brice
RV-9A 90897 FLYING
Old 01-29-2012, 11:18 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Those are standard items, B and C has them I believe.
Also, Stein should have them.
If you check the local NAPA store, they probably have them, but not too sure if there is a difference in materials or quality that you need to worry about.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-30-2012, 05:04 AM
TX7A TX7A is offline
Default B&C Link
http://www.bandc.biz/index.aspx
...under "Electrical Supplies"
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 01-30-2012, 11:29 AM
N15JB N15JB is offline
Grainger carries 3M brand ring terminals in the size you need
Jim Berry
Old 01-30-2012, 09:19 PM
BJohnson's Avatar
Default Perfect!
Thanks for the prompt replies. I don't know why I was thinking that they must not make them in that size for the smaller wire gauges. I need to get out more!
Brice
RV-9A 90897 FLYING
Old 01-30-2012, 09:59 PM
SteinAir SteinAir is offline
We try to keep large size/diameter ring terminals for wires all the way down to awg22...
Stein
Old 01-30-2012, 10:29 PM
BJohnson's Avatar
Default Master kit
Stein, I bought your master kit a while back but these were not in the kit. While you can't predict all that might be needed, a few of these for varioius wire sizes for the battery contactor size lugs would be helpful. I did not need nearly as many of the 16 awg - 14 awg fastons and ring terminals so perhaps these can be substituted.
Brice
RV-9A 90897 FLYING
Old 02-02-2012, 10:20 PM
BJohnson's Avatar
Default Shout out to Stein!
Came home from work today wishing I had gotten around to ordering the large ring terminals only to find the Stein had taken the initiative to ship some misc sizes to me without asking. Sure I got billed a small amount for shipping, but man, talk about timing! Now I don't have to spend my Friday running around the area hoping local/regional supplies were available!
Thanks!
Brice
RV-9A 90897 FLYING
