  #11
Old 01-30-2012, 01:34 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Red face Imagine this scenario!
John that looks good for you but imagine your heels resting 2 inches higher and then extending your leg all the way to the firewall and your toe would naturally move forward of your heel. Flightline interior carpet would lift your heel up to this height.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 01-30-2012, 02:01 PM
skydiverlv skydiverlv is offline
OK Bender, you holding out on us? What is running horizontal along the sidewall?
Larry Vandegrift
ULPower 260is
Old 01-30-2012, 02:04 PM
JBPILOT JBPILOT is offline
Default Apparently - you have not been paying close attention - - -
That is my "HEATER DAMPER DOOR" control. Go back thru the search if interested. Yesterday it was 27F in Iowa, and the heater works great. Nice of you to notice ! !
John Bender
368.4 hours
Old 01-30-2012, 02:07 PM
Default Jetguy - -
My Home Depot indoor/outdoor carpet is only maybe 1/4" thick. Ain't my problem man ! ! !
John Bender
Old 01-30-2012, 03:41 PM
MartySantic's Avatar
MartySantic MartySantic is offline
John Bender
368.4 hours
Copied John's design. Here are the photos,
https://picasaweb.google.com/marty.s...eat=directlink
Also photos of the Thermostatis oil thermostat and the Reiff preheater.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 01-30-2012, 04:25 PM
Ausflyer Ausflyer is offline
Default cheap carpet
Be wary John. I did the same, bought some cheap synthetic carpet, cut it to fit and it looked great. Got to thinking about fire safety so I cut a sliver off the edge of some scrap, hung it on a wire and lit it. A tiny flame became an 8 inch torch in seconds, with drips of burning molten plastic falling to the ground.
Out went the carpet. I cut the supplied wing walk adhesive material into 4 strips and fixed it to the painted metal floor. I think it looks fine (echos the foot pads up a level) and is easy to clean.
Rod
Old 01-30-2012, 05:22 PM
Default Good point Rod - -
Have some left over to trial burn. Maybe a thin rubber mat of sorts might be less flammable.
John Bender
Old 02-11-2012, 05:10 PM
rgmwa rgmwa is offline
Default Question..
Would anyone be able to tell me how much gap there is between the back of the rudder pedal and the firewall when the rudder is fully deflected?
Thanks in advance.
rgmwa
RV-12LR 912ULS
120346
