Old 01-28-2012, 06:09 PM
scsmith scsmith is offline
Default Dip stick keeps breaking!?!
My Dipstick broke off at the little pin in the cap. I drove the little pin out, punched the last bit of the rod out of the cap, turned the other end of the rod down to the right diameter, inserted it in the cap, drilled for the little pin, and I was back in business.
Then, 3 months later, it broke again!
What the heck? I wonder if there is some strange vibration at just the right frequency to fatigue the dip stick? Anyone else have this happen?
Is this a warning sign of something ominous?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 01-28-2012, 06:22 PM
Wayne Gillispie Wayne Gillispie is offline
Check prop balance. Change the orientation of the little pin. Where do you keep your oil level? Higher oil levels and thicker oil will dampen vibrations. Change your cruise rpm setting. That is all I can come up with.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-28-2012, 06:25 PM
Default balance and other ideas
Thanks for your ideas Wayne,
My prop was dynamic balanced about a year ago, and nothing should have changed since then. It feels VERY smooth.
I have, in fact, lately been cruising at slightly higher RPM than I used to. Normally 2400 but have been running 2430 or so. That could conceivably hit a natural frequency of the dip stick, although one would think the problem would be more widespread.
I keep the oil at 6 qts. I add when it gets down to 5. I use a quart in about 15-20 hrs that way.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 01-28-2012, 08:09 PM
AlexPeterson's Avatar
Mine has never broken, but it gets some abuse where it goes through the crankscase half holes near the bottom. One can see the wear marks. Wonder what kind of aluminum alloy they are supposed to be from?
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
