06-03-2006, 06:12 PM
Need Advice on 0-320H2AD
I am looking at a pretty sweet deal on a 1st runout O-320H2AD 76 series (<$2800 complete - no prop strike 1900TT) (no "T" mod done). I have reviewed the AD's and understand the cam issue and I have some questions since I am totally new to this.
Are there a lot RVs flying this model? I see tons of 172N models with tons of time but does this come at a huge expense to maintain these engines?
Is it hard (i.e. expensive) to fulfill the AD?
Is it worth buying a 1900TT engine only to have it OH in a couple of hundred hours.
Since I will be using this in an RV4, I can rebuilt it myself and have my progress followed by an AP/IA right?
Are the dual mags in a single case a real issue?
Can I do light aerobatics with this model?
Am I better off with a different model?
I've read some great threads on lycomings in general but I hope to find specifics on this model.
Any suggestions would be great. Thanks.
06-03-2006, 06:45 PM
O 320 H2ad
I choose the same engine for my project.
See Randall's narrative in the Firewall forward section
http://www.vansairforce.net/engines.htm
The single mag is used on many other engines, so I see it as a
non -issue.
There is a company in Canada that is producing a roller cam.lifter
kit if you desire.
The fuel pump is in a non=standard location, with fire sleeve it should be fine.
Auto Gas is not an recommended option for this engine. The engine mount is standard. Van's Baffle kit is usable but you will need to customize some pieces.
There a others that are flying that should add more information.
I would go the same direction again.
06-04-2006, 12:20 AM
Originally Posted by Alschief
The single mag is used on many other engines, so I see it as a non -issue.
Yes, but... there's always a but, right?
I've flown hundreds of hours behind these -H2AD engines, along with other dual mag/single drive engines in Mooney 201s, Cardinal RGs, etc... and for the most part they were reliable and trouble free. But, I once had a bad day instructing in a '79 C-172N; the mags were fine but the single drive gear failed. I was able to limp back to home base, barely... it's been 18 yrs and I don't recall the exact failure mode, but the mechanic said the single drive gear setup was coming apart. I'm not sure if it was the gear drive in the accessory case or the gears in the magneto case... either way I thought it was pretty lame to have two mags disabled by a bad drive.
This might've been just a freak occurance, one in a million type of failure, who knows. In the 18 years since I've flown behind these mags with no more trouble, and every night there are Piper Navajos/Chieftains out hauling the mail with these mags... but ya never know, it might happen again someday.
06-04-2006, 12:58 AM
One mag one EI
Easy mod is install a single mag and use a crank triggered EI for the second ignition. I think a single mag is a bolt in replacement. Just a thought. Besides your story I did read of one NTSB accident caused by the dual pak mag design.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
06-04-2006, 05:19 AM
0-320h2ad
Answers to your questions:Vern's opinion
Q:Is it hard (i.e. expensive) to fulfill the AD?
A: Not necessary according to most engine guys i've consulted with. It is very easy to monitor cam/lifter wear since you can easily remove lifters and observe cam lobes without splitting the case. As pointed out by others, there is a new roller lifter/new cam kit available that eliminates the need for T mod.
Q:Is it worth buying a 1900TT engine only to have it OH in a couple of hundred hours.
A: That depends on the actual condition of the engine when you buy it. If it has been flown often, cold wx starts have been aided by a sump heater or heated hanger, it may join others of its type which have repeatedly gone 3000-4000 hours such as the powerline patrol and fish-spotters who used H engines. If it has not been flown often and has excess wear now,it will not get better.
Q:Since I will be using this in an RV4, I can rebuilt it myself and have my progress followed by an AP/IA right?
A: Yes. Experimental means just that.
Q:Are the dual mags in a single case a real issue?
A: No problem. In fact, mine starts better than any Lycoming I've ever started. Get your mag overhauled by a good shop and it will serve you well.
Q:Can I do light aerobatics with this model?
A:It is no different than any other non-aerobatic Lycoming engine. Note: most RVers do not have 'aerobatic' Lycomings. I do everything but snap manuevers in my 6A.
Q:Am I better off with a different model?
A: That depends on your finances. The price you quote may allow you to get airborne considerably sooner. There will be prejudice when resale time comes along from others who have the same questions you have asked. Certainly a newer/more HP engine capable of using a CS prop would produce greater resale and performance. Again, that is all a question of ecomonics.If this price engine allows you to fly this decade, jump on it.
Q:Any suggestions would be great.
A: >On the RV-6A, Vans sells a special engine mount that has the top rear member arched slightly to allow the engine to fit. Many' RVers have modded the standard mount themselves. Ask for that mount when you order your finish kit. Should you re-engine later, other non-H Lycomings slide into place.
>The recommended oils must be used. They have an anti-scuff additive mixed into the oil.
>The H2AD is still listed in the Lycoming lit as current production model still available new from Lycoming. Parts are relatively cheap.
>Because of the forward fuel pump and the never-machined prop gov pad on the front (no-you cannot add CS prop to this engine unless you use an electric/non aerobatic prop) ,The cowling front may need to be built up slightly. Some use 'bumps' on the top cowl front.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
06-04-2006, 07:21 AM
H2ad
I Have a H2AD IN MY rv-7 i BOUGHT THE ENGINE FOR 3500 BUCKSWITH 1400 HOURS ON IT, IT WAS NOT A T MOD ENGINE AND FROM WHAT I HEAR THE T MODS STILL HAD PROBLEMS
When I bought the engine I was able to remove the lifters and check them out they were all fine the comp was good there was no metal in the strainer or filter
I sent the mags out to Maxwells in FL and ended up replaceing them with model 3000 which elimated the 500 hour AD for inspection and when I replace the mages I also installed a new coupler for the drive
I have since flown 100 hours on the engine and just did my third condition inspection all is fine
I have the vans mount cost 50 bucks more the baffels are no harder to do on this engine as it was on a 180 hp lyc
I'm in the process of painting my plane now and at this time i have orded a james plemum with the rings i'm not sure how they will fit becasue of the fuel pump and govenor pad, I will be starting that next week on the firts trial fit It looks like I can do it
Yes you have to mod the top cowl to fit two bumps worked great and most people never even notice the bumps
I have not been disapponted with the engine sure if money was not a problem or I would wants payments I would have 180-210 hp with cs but money is a concern this has worked out great yes if i ever sell it it will not be worth as much(?) but i have less in it
Fuel burn solo 2100 rpms cruise about 165 mph 6.5gph Two people some baggage full throttle 2500 rpm 9gph
I have started to buy some engine rebuild parts for when that time comes buy alittle at a time makes it easy I have the roller cam set up(got a good deal last year from canada)
RV-7 fuse painted in maine
02-27-2009, 10:13 PM
Helio, I tore down a H2AD last year. Pics are here: http://picasaweb.google.com/pilotandy/RV9AEngine#
You might want to pull the lifters to check for wear, and you might get some more clues while doing so. I believe there was at least one (maybe more) aftermarket cams for this engine. One was for a cam/lifters that used roller bearings. It's possible that these cams might not have had the pump actuator. Hopefully someone else can chime in with better info.
My engine is a stock t-mod 320-h2ad with no surprises, so that will perhaps offer another data point. Comparing my pics to yours, it seems like you should definately be able to see the fuel pump lobe.
To pull the lifters, remove the valve cover, remove the stamped rocker(keep track of shims!), remove the pushrod, remove the shroud clamp, remove the shroud, and you should be able to get the lifter to slide right out. You can use a popsicle stick to grab at the edge and pull it out if it doesn't come on its own. Be sure to keep them clean, and put them back in the same place you pull them from. Once out, you can inspect the lifter face as well as the cam lobe by looking down the lifter bore with a flashlight. At the very least this might tell you if you have one of the roller lifter kits, and also what condition your lifters/cam are in.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
02-27-2009, 10:26 PM
Originally Posted by ppxdf
Since this engine was installed in Cessna 172's, they didn't use (or need) a fuel pump so the plunger will not be there. In order to add it you will have to find the right plunger, split the case and install the install it.
Rather than going thru the trouble, I would suggest you consider going to dual electronic ignitions with dual electric fuel pumps. Forget the mechanical pump altogether. This is the route I've taken with my Rocket.
Personally I think the H2AD is an excellent engine, there is one in a C172 that lives in a tee hangar behind our home, and it went 3800 between overhauls, in a flight school airplane that got whipped on a daily basis.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
02-28-2009, 07:51 PM
Dear rocketbob
Could you, please, give more details about your "dual electronic ignitions with dual electric fuel pumps".
My H2AD is equipped with dual Mags Bendix D4RN-3000, instead of D4RN-2021. So, At first I am thinking to buy just the dual electronic fuel pump? What do you think?
