Old 06-03-2006, 05:54 PM
idleup idleup is offline
Question Considerations before closing the wing up
So what decisions need to be made before closing the wing up? I can think of the following:
1. Type of Pitot tube that will be used
2. Landing lights
3. AOA installed if going to be used.
Are those correct? are there any more?
- Matt
Old 06-03-2006, 06:10 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
auto-pilot servo?
Old 06-03-2006, 06:17 PM
Is there a way to put in an auto pilot servo without committing to the auto pilot system you are going to use? or does each one have it's own setup... honestly I have not looked at all at autopilots yet.
- Matt
Old 06-03-2006, 06:21 PM
N941WR's Avatar
N941WR N941WR is offline
This is somewhat implied but how about wiring conduit?
Also, some people mount their remote compass and OAT probe in the wings. (Mine are in the tail.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-03-2006, 09:50 PM
DGlaeser DGlaeser is offline
Default Autopilots
- Matt
Each manufacturer's autopilot uses it's own servos - they aren't universal or interchangable.
I know that TruTrack's can be installed after the wing is completed - and I suspect most (if not all) others can as well. Just make sure your wiring holes/conduit are big enough for the added wires.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 06-05-2006, 09:21 AM
Davepar's Avatar
Davepar Davepar is offline
I think SteinAir is now selling servo wire. You could run some wire for a future autopilot.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 06-05-2006, 10:54 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
2. Landing lights
- Matt
Location of pitot tube if not going with Van's. I've left my bottom skins off for so long because I have not yet decided this question.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-05-2006, 11:37 AM
atreff's Avatar
atreff atreff is offline
Default Anything for tips
Nav lights
Strobes
Tip mounted antennae
Old 06-05-2006, 11:40 AM
I installed the Vans conduit down the wing for that stuff. Thanks.
Old 06-05-2006, 11:50 AM
tomcostanza tomcostanza is offline
Default autopilot
I'm planning on a TruTrak autopilot. I bought the servo brackets and mounted the one for the ailerons in the wing when I built the wing. I'll also run the wire for the servo before closing the wing. Then all I'll need to do is bolt in the servo and plug it in.
Good luck.
Tom Costanza
RV-7A fuse
Tom Costanza
RV-7A Fuse
