I have the IO360-A1B6 forward injector superior cold air sump. The Vetterman crossover exhaust without mufflers work well. The only challenge is the sniffle valve port and control cable routing.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
