Old 01-25-2012, 07:06 PM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default RV-6 Pushrod Drawing
Hi my RV6 Drawing for pushrod F665, F790 and F789 is missing. They are all on the same page (DWG 35)
Does anybody have a copy of this, or could tell me the overall length of the tubes?
I do have the RV7 drawing but im not sure if the sizes will be the same for the 6?
Thanks AJ
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
Old 01-25-2012, 07:50 PM
flion's Avatar
flion flion is offline
I have a rev. 13 drawing 40 that shows F-689 as 47.5" and drawing 34 rev. 14 that dimensions F-690 as 78". Drawing 41 rev. 7 shows F-655 as 17.5". Those are the material lengths and don't include the end hardware. Drawing 35 is the instrument panel. Does that help?
EAA Technical Counselor #5357
Old 01-25-2012, 07:56 PM
WenEng WenEng is offline
Default Pushrods..
My RV6 plans show the F-665 pushrod on dwg 41.
F665 - 17.5 inches end to end into which you then thread the heim M3414 rod end bearings. The distance to the end to end midline of the heim bearing openings once threaded in place is 19.0 inches. It is 1/2 " hex 6061-T6 and you drill #3 1.25 inches deep and tap 1/4x28, 1 inch deep both ends.
F-690 Elevator control tube on dwg 34. 1.5 inch diameter, .035 thick 6061-T6 , 78.0 inches long end to end to which you then add the VA101 end caps and heim MD3616M bearings to each end. This is from the bellcrank to the back.
F-689 is the elevator push rod from the control stick to the bell crank. It is 3/4" .058" thick 6061 T6, 47.5 inches long end to end. It takes the VA115 threaded ends that get riveted in place with MD42BS pop rivets and then the heim 3514M bearings get threaded on.
Hope that helps..
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 01-25-2012, 08:10 PM
AJ85WA's Avatar
Default Great
Thanks guys!! That was exactly what i was looking for.
Have a good one
Completed - RV6
