Old 04-23-2014, 07:21 PM
Bill_H's Avatar
Bill_H Bill_H is offline
See this entire post. Page 13 has the split bulkhead and panel. http://www.vansairforce.com/communit...ad.php?t=64145
If you install the servos during construction it is easy. You install them when you are connecting up the flight controls. Best advice is also before you attach the tail to the fuselage. You can also order the servos (and their associated hardware) in advance of ordering the avionics kit.
Old 04-23-2014, 11:40 PM
RFSchaller RFSchaller is offline
I added inspection ports on the belly to avoid removing the bulkhead for annuals. I put one in place so that I can inspect the aft servo with a bore scope.
