Old 01-24-2012, 05:35 PM
n38139 n38139 is offline
Default Service Life of an RV?
I am in the market for an RV and have taken a look at a couple of higher time airplanes, close to 2000 hours.
Is there any discussion that anybody knows about on the issue of useful service life on an experimental or RV? I tried to talk to a guy a Vans about this but he was avoiding the answer (I understand liability) so does anybody know if there is a design limit or service limit? I am trying to avoid the answer of : "If you take care of it, it will last forever".
thanks
Old 01-24-2012, 05:42 PM
plehrke's Avatar
plehrke plehrke is offline
Very good question. As we get more airplanes up there in hours we will need to know what to expect. It would be great for some one (or two) to put together a list of things to inspect at different time intervals based on what they may be seeing on their conditional inspections.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 01-24-2012, 05:44 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
There are many RV's out there with 3500-4500 hrs still performing as they did day one. Look for the quality in the build and buy one.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-24-2012, 05:47 PM
Default Here's one...
TURBO
Ed DArcy
RV6-A N26ED / R-44 N7511G 900 hrs
Stuart, Fl KSUA / S WINDSOR,Ct KBAF/ Virgin Gorda, BVI TUPW
4,000 hobbs hrs since jan 2000. new thunderbolt , roller lifters, flowed intakes,installed oct 07
www.eaachapter692.org/ link to 5,000 mile heli trip and more http://gallery.mac.com/edarcy#gallery EAA AOPA FAC FABA QB VAF#840 SPA PRA OFFC
Reiley
VAF# 671
Friend of the RV-1
Old 01-24-2012, 05:54 PM
Scott Hersha Scott Hersha is offline
Nobody knows the answer to that because they haven't been around long enough. There are many, many single engine certified airplanes flying around with over 10,000 hours. RV's are built to the same standards (at a minimum) in terms of meterial strength, giving something back in stability for the sake of performance, but with superior materials. If the airplane has lived in a salty environement, take a good look at corrosion. If it's been primed inside, don't worry about it. The engine and everything else is time-limited and can be overhauled or replaced. Check service bulletins and also any AD's on certified components and let your conscience be your guide....
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 01-24-2012, 06:11 PM
David Z David Z is offline
I did my float rating on a 172 that had just shy of 40 000hrs. I'm sure it's over by now. 99% of that time is on floats or skiis. A life of landing on waves and snowmobile tracks is a lot harder on the airframe than paved runways.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage deburring and dimpling. So many holes
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 01-24-2012, 06:32 PM
AZtailwind's Avatar
AZtailwind AZtailwind is offline
Originally Posted by n38139 View Post
I am trying to avoid the answer of : "If you take care of it, it will last forever". thanks
First of all I don't believe a 2000 hour RV is "high time"- I would say that is well proven.
Some cracking may be found in some weak spots such as landing gear and empennage. Also some airframe details may need attention over time such as the canopy and cowl. I believe there are many models that are built with better corrosion proofing than my 1961 182.
But you already know the answer to your question- You can't avoid that answer because it has a lot of truth to it!
Brad Ransom
http://www.westcoastravens.com
RV-6A 180HP-acquired
RV-4 180HP-acquired
Old 01-24-2012, 06:43 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default DC3 C47
DC3 and C47 are not pressurized and built the same as our RV kit planes. Some DC3s have 50,000 hours.
Our RVs will last the same hours if the time life items are taken care of.
A cowl can replaced, enging mounts can be repaired or replaced. RVs do not have hardly any issues with the airframe. The design is well thought out and I expect some will get some really high times. Almost wish I had to fly to work and get several hundred hours every year. Like some So Cal RVrs do
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 01-24-2012, 07:10 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Service life of a Cherokee 140 wing (one that has not seen "severe duty") is around 60,000 hours, if it hasn't corroded to powder by then. Heck, even a Traumahawk gets 10K hours. I'd like to think that a well-built RV ought to last at least as long as a T-hawk
Neal Howard
Airplaneless once again...
Old 01-24-2012, 07:24 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Only if it was primed correctly.
I kid, I kid.....
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
