01-24-2012, 04:34 PM
I have a PC680 that is 7 years old... ask them if their battery will perform as well?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
01-24-2012, 04:50 PM
Battery Life?
The PC 680 in my EXP Super Cub has been in it since before the first flight April 2004. It still is good even on a cold day.
The PC680 in My RV8 is still going strong since mid 2007.
I have another one in the shop that still is good that was removed form a crashed airplane, it is dated 2002
The joy of a cheap price is long forgotten if the product is inferior, and has to be replaced.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
01-24-2012, 07:35 PM
AH is not the whole story, but...
There are alternatives to the PC6xx's that are *much* cheaper & will work just fine.
I couldn't find a datasheet for that particular battery, but I've used similar models, with the relatively thin terminals, in RV-4's. Most that I've seen with those thin terminals are somewhat limited in their 'cold cranking amps'. They are typically designed for slower discharge rates, as might be seen in an uninterrupt-able power supply. They will start an O-320, but with performance about equal to an old flooded cell a/c battery, & my experience is somewhat limited lifespan of maybe 2 years. If you choose this quality battery, I'd suggest picking one that's rated at 20 AH instead of 18. They typically fit the same mount dimensions, and can usually come closer to PC6xx performance at the really low price you're looking for.
Since the Odyssey is the 'gold standard', I'd suggest looking at the specs; you can go to
http://www.odysseybattery.com/literature.html
& click on 'Odessey Owners Manual' to see the specs. look for minimum 220 Cold Cranking Amps (higher is better), and around 7-8 milli-ohms internal resistance (lower is better).
There are other clones of the PC680 & PC625 that have been selling recently for $60-$80 shipped that are designed as direct replacements, capable of very high short term current dumps for starting.
Here are a couple from a company I recently used via Amazon;
http://www.amazon.com/gp/product/B00...n=&s=&v=glance
and
If you use the big G & enter 'PC680' or 'PC625', you'll find dozens of good sources.
Hope that helps...
Charlie
01-26-2012, 07:11 PM
Great Info
Thanks, Charlie; that is some great information. The CSOB of me just cannot spend double or treble the money when the cheap one looks just as good on paper. I understand it may not last as long, but I will give the cheap one a try and report back my experience; in a few years, I hope ;-)
Robin
01-26-2012, 07:23 PM
Make sure and always read the fine print, some of the batteries noted as direct replacement are actually lead acid batteries and not glass mat.
Reiley
VAF# 671
Friend of the RV-1
01-26-2012, 07:41 PM
A reasonable caution, but be sure that it's understood that the 'glass mat' batteries are, indeed, lead-acid batteries. Just distinguish between the new tech & old flooded cell designs.
It's fairly safe to say that if it will fit where a PC6xx fits, & crank a 360 cu in Lyc, it's probably *not* a flooded cell battery.
Charlie
01-26-2012, 08:00 PM
I looked at a PC680 look-a-like when I replaced my battery. Then I kept remembering stories of laptop computers and cell phones with cheap Chinese made batteries catching fire, unexpectedly. Just the thought of that thing catching fire was enough to make me want only the Odyssey.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
01-26-2012, 08:16 PM
I've got a buddy with a PC680 in his RV-4 that's been in service for almost 7 years, and it's finally this winter not holding a charge very well and due for replacement.
Think he got his money's worth?
Neal Howard
Airplaneless once again...
01-26-2012, 09:05 PM
Just found a New PC 680 for $99.73 online... Smoking Hot Deal!
Reiley
VAF# 671
Friend of the RV-1
