  #11
Old 06-06-2006, 08:56 AM
Scott Will's Avatar
Scott Will Scott Will is offline
And here's the same CH grips with the relays built in. Wiring is soooo much easier and you dont have to fabricate mounts for the relays. I think the relays add like $50 to the total cost. That's less than buying two relays from Ray Allen Co.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 06-06-2006, 09:19 AM
RV_7A RV_7A is offline
Now thats what I'm talkin about! Hey Scott W. wanna trade?
Mr. Haskins... any questions?
-Jeff
www.JeffsRV-7A.com
N808TX
Old 06-06-2006, 09:33 AM
dan's Avatar
dan dan is offline
Originally Posted by RV_7A
CH man, they now have relays built into the grip which makes wiring quite simple.
Quite simple until a relay goes T/U. Can you replace the relays that are built into the grip? I assume the answer is yes...just playing devil's advocate.
Dan Checkoway RV-7
Old 06-06-2006, 09:45 AM
Half full, half empty. If you gotta replace a part, you gotta replace a part. In my case if a relay goes bad, I'll be ordering a new one from Aircraft Extras . com. If I had the new grip like Scott I'd be ordering a new grip from CH Products.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 06-06-2006, 09:56 AM
dan's Avatar
dan dan is offline
I'm just encouraging folks to consider ease & cost of maintenance. If you'll only fly 20 hours a year maybe that's not as big of a consideration.
Dan Checkoway RV-7
Old 06-06-2006, 10:54 AM
Scott Will's Avatar
Or I could argue that there are more physical wire connections with the external relay setup. six and one half dozen of the other. One thing's for sure, I'll be no where near 442 hrs/year as dan has averaged!!
The guy at CH products was quite knowledgeable. He has a -6 if I recall.
Does anyone want to buy my two spare Ray Allen relays?
Scott Will
http://will2fly.com
CFI - CFII - MEI
